LS3037
   / LS3037 #1
Icenam
LS XR3037HC
My LS3037 has 400 hrs on it and keeps losing power and stalls. Oils been changed as well as fuel filter. No warning lights on dash. 20f out. Any ideas?
   / LS3037 #2
Could be a lot of fuel related things. 20deg f is a little warm to be having fuel issues, but summer untreated fuel could be causing the fuel to plug the filter (Cold Filter Plugging Point). My notes say this can occur at between 10-15 f.
Start by thoroughly bleeding the fuel system. The procedure varies by machine type. If the problem continues, check fuel flow at several points from the tank out. If your machine has an electric lift pump, confirm that it is running with the key on. Finally, cracked or leaking fuel lines can suck air causing problems.
   / LS3037 #3
I agree with the above. I would start as close to the tank as I could ensuring free flow from the tank. Algae and crud can build up in there preventing free flow of fuel. If that's the case very little will even GET to the filter. Sometimes new filters can be defective, too.
   / LS3037
Thanks for the reply. Found out it was a pre filter problem that LS didn't have in the manual.
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
KUBOTA SVL97-2 SKID STEER (A51242)
KUBOTA SVL97-2...
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
Seppi Mini BMS 85 Mulcher excavator attachment (A52128)
Seppi Mini BMS 85...
