ls185 blows 5amp eic fuse(elec instrument cluster) and quits
   / ls185 blows 5amp eic fuse(elec instrument cluster) and quits #1
phixdo
new holand ls185b
was running fine then dash started flashing volts and slowly shut down was slow to crank once before that, thought the battery was bad so got new one and with a little trickery jumped the cables to start it from battery sitting outside machine because boom was down in the way to replace, still couldnt get to crank and found fuse blown, replaced fuse and it started fine bit will only run around 5 minutes before fuse blows again. any suggestions
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2011 NORAM POWER...
Tool Box with miscellaneous items (A53117)
Tool Box with...
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
Unused Delta Crash...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
