RandyinMS
Bronze Member
My LS XR4050 Hdro sometimes losses RPM and power. I'm right at 285 hrs.
More details
Mostly this happens when I'm using the chisel plow (7 tine).Now i have used the chisel plow and had no problems for the past couple of months. I run it at about 2600-2800 RPMs in first gear and its working hard but doing the job. The other day I was using it and in the midst of working the RPMs dropped off and power went away. Its not over heating, no warning lights and its not bogging down the RPMs drop. Went out this AM did some more this time using the draft control, chiseling shallower then I normally do and seemed to be working good for about 15 minutes. I stopped and put some fuel in went back to finish and it started to do it again.
So I slowed down a bit and by modulating the forward pedal I can ease up a bit when the RPMs start to drop and keep it going. Even going back to my shop the tractor's RPMs dropped going up a hill I go up every day driving just the same as always 2200 RPM in 2nd.
I've called the dealer and he had no answers but to drop a couple of tines. I'm thinking its something else because I have used it before,much harder then today and not had a problem.
Any thoughts?
More details
Any thoughts?
