Oil & Fuel LS XR4140H crush washer for oil drain plugs (x2)
/ LS XR4140H crush washer for oil drain plugs (x2) #1
neverfailyou
North Alabama
LS XR4140H. Ford 1720
Any body have a source for these crush washers on my 2017 LS besides the dealer?
/ LS XR4140H crush washer for oil drain plugs (x2) #2
Where I live I would shop the large Ace Hardware & Farm Supply.
Ace has crush washers in the hardware bins with nuts, bolts and etc.
Fastenal would probably have them too, if you are near one.
NAPA would also be a likely source.
eBay: oil crush washers: Search Result | eBay
/ LS XR4140H crush washer for oil drain plugs (x2) #3
Amazon
/ LS XR4140H crush washer for oil drain plugs (x2) #4
Any auto parts store....
/ LS XR4140H crush washer for oil drain plugs (x2) #5
Never replaced one in the last 20 years. I just anneal the old one and reuse it.
/ LS XR4140H crush washer for oil drain plugs (x2) #6
Have you checked out Rock Auto in
Madison, Wisconsin??
willy
/ LS XR4140H crush washer for oil drain plugs (x2) #7
Somehow my comment got misplaced but, I anneal any and all of my copper crush washers and re-use them. Easy to do. Just heat them to dull red and allow them to cool naturally. Copper work hardens but is easy to soften again.
/ LS XR4140H crush washer for oil drain plugs (x2) #8
Lots of drain plug washers are not made of copper
/ LS XR4140H crush washer for oil drain plugs (x2) #10
Anybody know what size these washers are (and all the others on an XR4145)? I'd rather not have to empty every reservoir just to retrieve an example washer before running to the hardware store. In particular, my LS leaks trans/hyd fluid pretty badly. It's hard to tell the actual source, unfortunately.
/ LS XR4140H crush washer for oil drain plugs (x2) #11
No clue but auto zone will have replacement copper washers in stock. Really, they are reuseable you just have to anneal the used ones. Easiest way is heat them on an electric stove burner until dull red and let them cool naturally.
Honda UTV (A56859)
Honda UTV (A56859)
Enmark Z Spray (A53316)
Enmark Z Spray...
2019 Ford F-350 (A55973)
2019 Ford F-350...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2009 Honda Civic Sedan (A59231)
2009 Honda Civic...
(8) UNUSED 9' X 5' WROUGHT IRON SITE FENCE (A60432)
(8) UNUSED 9' X 5'...
