gphil12873
I'm just going to let anyone know if they ever have this issue. Not saying that this is the only reason why it would blow this fuse. BUT....It will be hard to explain unless you take the lights apart that are on the grab handles as you enter the cab. The running light is at the bottom is just held in by two metal clamps. I just so happen to grab the light and see if was loose. It was slightly. Mine got bump hard enough that the bulb on the bottom popped out and wedged itself against the ground terminal and was causing the fuse to blow. Glad it was simple and I just happen to check it. Cause it would have been a gremlin to chase down. When the fuse blows you lose your digital part of the dash. The hour meter portion and the radio will quit. Everything else works. You will get the parking brake beeper constantly when your in motion. Goes away when stopped. Just sharing a little something that someone may check if it ever happens.
