LS tractor bucket flop problem
/ LS tractor bucket flop problem #1
George2615
Super Member
Central Square, NY
LS XR3037HC
I've noticed a lot of LS tractor owners have a bucket flop problem. Raise, lower, and curl functions all seem to work fine. But when you go to dump mode in order to back drag you have to bump the joystick to get pressure to keep the bucket where you want it. If you just go to dump mode and lower the bucket to the ground the bucket will flop around like there is no pressure.
This question is to all the hydraulics experts. Is it possibly a loader joystick valve problem, pump problem, or what. Seems like it gets air bound in dump mode. If I go to dump mode while the loader is raised, get off the tractor and grab the bottom of the bucket I can move it back and forth. Many LS members have complained about this. One member installed an inline flow restrictor valve but I don't know if this is the answer. I'm no hydraulics expert so on behalf of LS owners it would be nice to know why this happens and how to cure it.
Loader valve does not have fast dump position.
/ LS tractor bucket flop problem #2
If you have your loader raised, with the bucket empty, fully cycle the bucket curl circuit a few times, (5?) Then put the bucket so that the lip is hanging down straight towards the ground. Does the lip of the bucket now flop back and forth and if it does, how much does it move, 2-3" more?
/ LS tractor bucket flop problem #3
Mine also flops when dumping a load. It seem like the load will dump faster than the hydraulic pump can put fluid in behind the cylinder. I don't understand the hydraulics enough to know how it does this without getting air trapped.
/ LS tractor bucket flop problem #4
Does your loader have a detent valve installed? If so read up and learn how it is used for back dragging loose materials. Years ago a detent was a option on most tractors but has become standard on many units.
/ LS tractor bucket flop problem #5
On my tractors with FELs, operated with a joy stick, the joy stick has 5 positions. The 5th is nothing more than the dump lever pushed all the way down and this is called "Float". In essence, the bucket is unhooked from the hydraulic pressure and the the drain ports are open...no hydraulic fluid (under pressure) applied to the bucket.
You may be just pushing too far on the stick. Look on your valve at the cylindrical caps installed and see if you have one considerably longer than the other. If so going to bet that's a floater and as I said, it is activated in the dump mode by pushing the stick all the way to the stop. So the best way to use dump when you want bucket control is just push the lever far enough to get the system to move and push no farther unless you want float.
Float is designed for scraping materials off hard surfaces, or dragging the bucket where it can follow the contour of the ground under it.
HTH,
Mark
/ LS tractor bucket flop problem #6
Gary is right most tractors are this way, just hold lever a few seconds and then back drag.
/ LS tractor bucket flop problem #7
That's what I have to do to get tension on the bucket for backdragging
/ LS tractor bucket flop problem #8
HTH,
Mark
Float should be for the boom not the bucket, back dragging works a lot better that way.
/ LS tractor bucket flop problem #9
Every brand of small machine that I test drove had play in the bucket. Usually the smaller the more flop. Our MF 1529 has ridiculous flop. To me its just part of having a small pump.
/ LS tractor bucket flop problem #10
Does the LS have a regen spool on the dump circuit?
When dumping the loader, you are basically opening the rod port to tank, and pumping fluid in the base port by the pump. Well, the only thing keeping gravity from taking over is whatever vacuum the rod seal can hold back, which aint much. So the result is, gravity dumps the bucket and expels the fluid out of the rod side faster than the pump is filling the base end, so the result is air gets sucked in around the gland seal. Now you have a floppy bucket.
In regen mode, it dont open the rod port to tank. Instead, it also gives it pump pressure, so both ends of the cylinder get pressure. This keeps air from getting sucked in and will keep the bucket from getting floppy. In the manual, it would be listed something like fast dump.
The key is to find out if your tractor has regen, and if so, is it the first position of the lever, or second. On my kubota, regen is the first position. I have heard on some others and on aftermarket valves that its the second position. That would be odd for me as I am not used to pushing the dump all the way.
/ LS tractor bucket flop problem #11
LD1 s correct on the air getting drawn into the cylinder but it is not drawn in around the rod seal.
When dumping a load the rod end is under pressure created the induced load of the bucket. This induced load forces the oil out of the rod end faster than the pump flow rate can fill the cap end. This causes a vacuum in the cap end which leaves an air pocket in the cap end of the cylinder.
Some ways used to fix or reduce this happening.
Regen spools: Like LD1 states these do not vent either cylinder port to tank so now the pump only has to replace the volume of the cylinder rod.
Flow controls or orifice: These will also reduce the flop if sized or set properly but have there limitations since they are fixed restriction. Changing the load on the bucket, RPM's of the engine, etc. will chnage the amount of restriction required.
A spool designed to meter flow out of the rod end while allowing flow into the cap end is also an option used on larger more expensive equipment. These spools have asymmetrical flow rates which help prevent the runaway load.
Counterbalance or brake valves: These require a constant pressure to allow oil to pass and and be different pilot ratios to limit the brake effect.
/ LS tractor bucket flop problem #12
I will check and see. Would a pic of the valve help?
/ LS tractor bucket flop problem #13
Dont take this the wrong way as I am not looking to stir things up or have a debate, as I know you know more than most on this forum when it comes to hydraulics.....
The rod end isnt under pressure when dumping, as it is open to tank and just "flowing". only pressure is just the resistance in the lines for that oil to return to tank.
Hydraulic fittings and hoses seal against the hydraulic pressure as well as air/vacuum. the air that gets into the system can come from anything not designed to seal against vacuum. That would only be tank vent and rod gland lip seals.
If air getting in there under vacuum is not coming from the rod seals, where do you believe it is coming from? (dont really have any way to prove one way or the other, and I honestly dont know, as it really doesnt matter where it comes from, as long as you know its there and how to address it)
/ LS tractor bucket flop problem #14
Pic of the valve wont help much. But if there is a sticker/diagram near the valve that shows the loader functions......or one in your manual that explains the functions.
/ LS tractor bucket flop problem #15
LD1
Agree don't want to start a debate but if you put a gauge on the rod end of the cylinder when dumping it should never read a vacuum unless you have some super high velocities. There is always some pressure required to force the oil out of the cylinders, through the lines, valves, etc back to tank. The air is in the blind or cap end of the cylinder caused by the vacuum in that end. The air is drawn out of the oil and or possibly through the fittings on the cap end. The amount of air depends on so many factors it is hard to even calculate. Some of these factors are:
Splash in the reservoir / transmission. The gears turning in the oil cause some air to be entrapped.
Oil temperature: As the oil temp varies so does it potential for holding air. As oil/air heats up they expand.
feathering or flow restriction. Flow restrictions also cause air oil separation this may be happening at the valve.
110% agree this is a difficult concept to explain and grasp.
I'll check it this weekend. As far as I know it does not have regen or what I called fast dump as my other tractors had. I'll try the dump mode slowly and see if it stays in place. As it is now, if I angle the bucket down say 10-20 degrees using dump mode to back drag then put the loader in float mode, when the bucket touches the ground it will go back to almost flat bottom due to no pressure holding it in place. Then I have to hit dump mode again to force the bucket to stay at the desired degree to back drag.
I think it is a trait of all LS tractors and a few other brands. I only started this thread because myself and many others have questioned why it does this and what would be the cure. My joystick is cable operated to the spool. All previous tractors I've owned or used had the joystick attached directly to the spool valve.
/ LS tractor bucket flop problem #17
No fast dump here. Checked the loader operation diagram and tried to fast dump.
/ LS tractor bucket flop problem #18
Are you saying the loader diagram don't show fast dump? Or you just aren't noticing it dump any faster.
The detent on some valves is very subtle and almost non existent even though it has regen.
You may not notice a difference in speed because gravity causes it to dump fast even in slow mode...so fast it causes air and thus the problem.
Course, it may very well not have regen either. If that's the case, it's just the nature of the beast.
Have you tried putting the bucket flat on the ground and dumping to the desired backdrag angle (while simultaneously lifting) to prevent gravity from pulling the bucket open faster than fluid can fill? That should result in a less "floppy" bucket
Loader joystick diagram does not have fast dump.
Diagram shows joystick positions for loader up, loader down and float, curl up, and dump. Joystick can also be moved diagonally for lift and curl or lower and dump dual function operating.
Another member posted a video of his LS although I don't remember who nor could I find the thread (A sign I'm getting old and suffer from CRS) showing he raised the loader arms and put the bucket in dump mode, then got off the tractor and walked up to the bucket and with his hand could push the bucket back and forth like there was no pressure in the cylinders to hold the bucket in place.
/ LS tractor bucket flop problem #20
Right, the loader diagram doesnt show a fast dump. And slowly pressing right on the stick to all way is s short even travel.
Just to be clear I have no issue with the loader control. Its a small tractor and they all have their personalitys.
To backdrag after dumping I just leave the bucket down and drop it into float and adjust from there.
2006 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2006 Ford F-150...
2023 Chevrolet 1500 Silverado Z71 4x4 Crew Cab Pick-Up Truck (A59230)
2023 Chevrolet...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59905)
2021 KENWORTH T680...
7021 (A55851)
7021 (A55851)
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
