LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #271
Deezler, I normally run 1600-1700 when going firewood. Actually never operate less unless getting off and on changing an implement, moving something or wrapping a chain around something.
Still think I do not need to idle before shutting down?
Again, just my opinion, but at 1600 rpm of just driving around on flat ground carrying firewood, you're not working the engine much, and the exhaust/turbo shouldn't be all that hot to begin with. In such cases I tend to idle for just 10-20 seconds and then shut down, no harm at all in that approach. Granted, my Kioti is not turbocharged, so it's less relevant for me.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #272
100% agree to that. I do the same.
Just went over 600hrs, and had another Regen at 599.
That puts me at 50 regens in 600 hours, what should be somewhere in the neighborhood or 12 regens, is at least 50, with the ones I caught an average of every 10.16 hours and an actual clock value between 1 and 29 hours between.
Original post updated with data current as of today.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #274
Purchase one that regenerates automatically with no owner assistance (See New Holland Workmaster)
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #277
Hey, Champ. I don't know if you know this, but the small Boomer and Workmaster New Holland (and their CaseIH cousins) are just rebadged LS tractors.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #278
I think all brands regenerate automatically.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #279
Fortunately so far my XR4155 hasn’t had this problem but it currently only has about 470 hours on it, usually regenerates between 30-50 hours.
   / LS SAYS A REGEN EVERY 2 HOURS IS NORMAL (Update) 600hrs, 50 regens #280
My XR4140 regens about every 50 hours as well. I never operate it at 1700+ RPM unless running the PTO
Air Compressor (New/Unused) (A59225)
Air Compressor...
PALADIN INDUSTRIAL SCREENER (A58216)
PALADIN INDUSTRIAL...
2009 Ford Crown Victoria Sedan (A56859)
2009 Ford Crown...
GEARMATIC WINCH CABLE DRUM (A58216)
GEARMATIC WINCH...
Deere 333G (A53317)
Deere 333G (A53317)
Giyi Mini Grapple (A57149)
Giyi Mini Grapple...
