Mattbaker162
- Joined
- Dec 30, 2022
- Messages
- 5
- Tractor
- John deer 4020
I want to pre apologize because I know my explanation of the problem will be lengthy. It will be that way because I want to make sure I get aa much information about it out there to avoid dead ends and putting in more time than needed. What I have is a 2020 mt225he with the mitsubishi s3l2. Now before I started working for my boss I'm told the fuel pump failed and was changed out. Now this is the most frustrating part for me is that not a single person seems to be able to remember if the problem was there before the fuel pump was done or not but that point is mute because I have since changed the fuel pump. The problem occurs when you curl the bucket with a load or curl and try to go up or down at the same time. If you turn to sharp going up any kind of grade in medium and high. When I say loss of power I mean it bogs right down to an idle and a few times has stalled. What I have checked is all the fuel lines and tank for obstruction and all were clear. I've bled the entire system multiple times just to be certain there was no air. I have roughly confirmed that the injection timing is accurate although it was dark and hard to get an absolute accurate reading and am going to run a more accurate test soon. I serviced the entire tractor to eliminate any filter concerns and to ensure all fluids were filled and clean. My thoughts moving forward is to check valve clearance as the machine just rolled 500 hrs. I'm also considering that the muffler might be restricted in some way and while I always seem to have good fuel flow I also plan on running it with the cap loose to verify it is nothing to do with the vents. Am I heading in the right direction or am way off base?
