LS MT125 bad transmission, replacement available?
   / LS MT125 bad transmission, replacement available? #1
johng650
MF GC2310
Hi everyone. I have an LS MT125 that I got for cheap. The problem is the transmission is in very bad condition. The previous owner hit something with the hydraulic oil filter (no guard installed) and ran it out of fluid. Then kept trying to make it go until it started making very bad noises.
I've removed the transmission and have started disassembly. There is so much metal debris it's just incredible.
Best case at this point, I have to replace every bearing and seal in the gear case, the HST pump and motor, as well as all the HST plates and bearings. Basically everything inside the HST case.
Has anyone been able to source a new, complete transmission for an MT 125? How about just the HST unit?
If anyone is interested I have a YouTube channel and I'm documenting the rebuild/replacement there. Here's a link to the first video.
Also, I have an extra paper copy of the service manual for the LS MT125. if you want it contact me and we can arrange shipment.
Thanks in advance!
1985 Ford Ltl9000 Tender Truck (A52128)
1985 Ford Ltl9000...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
2021 CATERPILLAR 279D3 SKID STEER (A51242)
2021 CATERPILLAR...
2023 JOHN DEERE 50G EXCAVATOR (A51242)
2023 JOHN DEERE...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
