LS MT125 2021
   / LS MT125 2021 #1
jave2000
LS MT125
Any one else have this problem with this brand tractor (and have a solution). The F3 fuse blows when the ignition switch is turned on. Originally the F3 fuse blew out while in operation, using the loader. I’ve checked the safety switches for connectivity, which seem good. Thanks for your ideas and input.
   / LS MT125 2021 #2
If it's blowing the fuse, there is a short somewhere.
You'll need to figure out what circuit that is, trace the wires and see which one may be damaged.
   / LS MT125 2021
Thank you PTSG. An excellent local technician did exactly that. He found two wires from the alternator rubbing on the engine block. Repaired the wires and now the tractor is working (not blowing out fuses).
   / LS MT125 2021 #4
That'll do it. A fairly easy fix, albeit, stuff like this can often be very hard to find.
Thanks for the update.
LOT LOCATIONS (A51222)
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A50854)
2000 GMC C7500...
2016 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2016 VOLVO VNL...
