LS G3033H Bell Housing SAE # or??
   / LS G3033H Bell Housing SAE # or?? #1
Ym155d
Magalia, Ca
Yanmar 155d
What bell housing does LS use in the G3033? Curious in case my motor ever goes what my options are for replacement. There are plenty of Mitsubishi engines that are significantly cheaper than LS' engine. Has any found out what enginethey are compatible with or if they are stand alone?
   / LS G3033H Bell Housing SAE # or?? #2
Wow you really seem to be looking way into the future. What's your worry is there some reason you are worried, are you having problems?
Yeah, hopefully and probably looking way into the future but still very curious as to what engine the L3BL is an what bell housing it uses.
It looks as though they used to use Mitsubishi engines.
So far I am liking the tractor I purchased. I am; however, wishing I had spent a little more since I am making payments anyhow and got the R3039H because it is physically the same size and lifts quite a bit more.
Doing a little research on here.... Montana or parent company LG used Daedong 3A165-LG engines in the 3240 series tractor. These engines were 3 cylinder 32-34 hp. Kioti uses Daedong 3A165... minus the LG at the end. It looks as though the engine might be a Kioti/Daedong equivalent rather than a Mitsubishi. Any thoughts?
   / LS G3033H Bell Housing SAE # or?? #5
I read that that LS has a license to build the Mitsubishi engine and stared a year or two ago to do that. I did notice the wording change on their web site.
Model (Tier 3) Mitsubishi S4L2
Model (Tier 3) S4QL-D (Mitsubishi origin)
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2019 Ford F-450 Utility Truck, VIN # 1FT8W4DT8KEF27612 (A51572)
2019 Ford F-450...
2015 VOLVO VNL TANDEM AXLE SLEEPER (A52577)
2015 VOLVO VNL...
YANMAR YT359 TRACTOR (A51247)
YANMAR YT359...
2015 International ProStar Truck, VIN # 3HSDJSNRXFN563873 (A51572)
2015 International...
Clark G500-50 4450lbs Propane Forklift (A51691)
Clark G500-50...
