LS 4155HC Brush Guard
   / LS 4155HC Brush Guard #1
Budlight592
Tarkington Prairie, Texas
2017 LS XR4155HC
Had my local guys do a little work for me on the brush guard. It was cheaper to pay them then buy a welder and start working on it myself. I wanted front and side protection also wanted to tie in the welded box frame together in the front. So the front plate that's welded to the from is now also tied together to the side frames. Don't think you could pull it off now if you wanted.
The welder and projects associated with it come later, but need this done now. Let me know what you think or if the photos cant be seen.
Flickr
   / LS 4155HC Brush Guard #3
Looks nice. Guessing you have to remove it to get to the radiator screen?
No it clears it but not by much. Now the air filter turned into being a little bit of a trick but I think its worth the time considering the protection that it provides.
   / LS 4155HC Brush Guard #5
Looks like a nice heavy duty solution. Adding the pull ring was a good idea as well. You might want to think about some additional lights since your screen is going to block the headlights pretty well. I added an LED bar between the front factory worklights on mine and it is much better than the factory headlights.
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2015 CAT 299D2 XHP SKID STEER W/ BUCKET (A50322)
2015 CAT 299D2 XHP...
Caterpillar Loader Quick Coupler (A52128)
Caterpillar Loader...
2014 Freightliner M2 106 Ambulance (A50323)
2014 Freightliner...
