LS 4041 no start
   / LS 4041 no start #1
SE Iowa Plotter
Iowa City
LS 4041
Hello all, I just signed up here today, although I have read some posts here and there over the past few months. It seems as though there are many very knowledgeable and helpful people posting here. I hope to contribute over time as well, although I am by no means a tractor expert.
I got my first tractor, an LS 4041EZ, about 9 months ago now and use it at my hobby farm and primarily use it to prepare and plant food plots for wildlife, etc. I have 6' Brush Hog mower, a 6' 3pt disk, a 6' Land Pride box scraper and a 10' or 12' wide drag/harrow. I maintain trails and about 20 acres of food plots at this time.
So far, I really like my LS tractor...but I do have a current problem that is vexing. About 3 weeks ago, I used it on and off for a few hours and shut it off and turned in back on without incident or warning. Of course, when I am furthest away from the buildings AND on the other side of a creek crossing that needed to be tuned up...it wouldn't start. Harrumph! :thumbdown: No dash lights came on either, so I suspected a bad battery. I scrambled into town and came back with a new battery and installed that and there was no change. I left it as is in the field at the time.
Short story...when I returned to it this past weekend, with some parts in hand to try to repair...it started on the first try and ran flawlessly for the next couple of hours. (Yes, I went straight to the janky creek crossing and fixed it first!) I ran the tractor without incident for a couple of hours, shut it down...in the yard, and went on to other tasks. When I went to start it again about 6 hours later to put it away...same thing as before...no start!
There are no lights on the dash, the blinkers do not work, the emergencies do not flash, etc. I shifted everything into neutral, turned the PTO switch back and forth, (it was off), and still nothing. I still have the parts to try...a fuse(which to me cannot be it since it started once now), the ignition module, a PTO switch, etc. So when I return this weekend I will start swapping parts, but I thought I would through this out there and see if anyone can give me some pointers and/or likely suspects. The battery is new, the connections to the battery are good too. TIA.
   / LS 4041 no start #2
I had a similar issue with my 4041EZ. They sent me a new shuttle lever and a new clutch switch and all has been well since. I was informed by a dealer here in PA that there was a recall a while back on the EZ shifts but he would not offer much more info. Something about a long delay when shifting from forward to reverse or neural to forward. For what it's worth.. I hardly ever use the push button clutch switch on the shifter knob. I use it as if it were a standard shuttle shift tractor. Only reason I got the EZ shift is because when I went to order the shuttle from the dealer all he had was the EZ so he sold it to me for the price of a shuttle machine. When I had my start issue the sent a couple of relays but those were not the problem. My guess.. Neutral switch in column or clutch switch.
HOWSE 67" BOX BLADE W/ SCARFIER (A51243)
HOWSE 67" BOX...
UNUSED JCT QUICK ATTACH BACKHOE DIGGING ARM (A51244)
UNUSED JCT QUICK...
2013 Acura ILX Sedan (A50324)
2013 Acura ILX...
6-Row Rolling Cultivator Narrow INOPERABLE/PARTS ONLY (A52128)
6-Row Rolling...
UNUSED FUTURE MINI EXCAVATOR HYD WOOD DRILL (A51244)
UNUSED FUTURE MINI...
SET OF SKID STEER QUICK ATTACH PALLET FORKS (A51243)
SET OF SKID STEER...
