JJZ 109
Veteran Member
- Joined
- Feb 7, 2009
- Messages
- 2,175
- Location
- Lake Ontario/St. Lawrence River
- Tractor
- Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
Yesterday I had 3 100 pound LP gas cylinders refilled. Brought them home and attached the lines to 2 of them. 1 to the kitchen stove and another to the furnace. The third is spare.
Today, wife and I could smell LP and hear hissing. The 2 tanks attached to lines appeared OK. The spare tank had fuel leaching out of it. The valve was cranked shut as well as the bleed valve. I cracked it open for a second and then closed it right back up. All seemed well. 20 minutes later the same thing happened again. There appears to be a pressure relief valve of some sort directly opposite of where the line would screw into the shut off valve. That's where the visible gas and hissing were coming from.
When the kid at the local hardware filled the tank, I could hear the pump sound like it couldn't put any more into the tank and the meter stopped ticking it off while the kid yakked on. The afternoon sun was beating on the tank at the time of the incident. Is it possible that the tank was overfilled and that the sun had expanded the gas enough to activate a pressure relief? Never saw this happen in several years of using liquid propane.
