LOWERING SEAT
   / LOWERING SEAT #1
bluefine409
2007 CC GT2544
Has anyone lowered the seat on a 2544? I am going to tackle it, but would like to know if it's been done before so I will know how to start and if there are any problems encountered.
   / LOWERING SEAT #2
I need seat adjustment too.
I need to figure out a way to make the seat on my 1864 go back further :)
I'm 6'4" 350lbs. I need more room :)
-Larry
   / LOWERING SEAT #3
To move seat back! remove the whole fender it hold the seat.take deck off,there are two set of bolts under foot rest on each side, and the middle there are two bolts.remove the bolts from the bracket fender reinforcement.which is bolted to frame. unscrew the gas cap.and remove fender. you might have 3 to 4 inches to redrill holes seat set up, but make sure reinforement still bolts to frame.
   / LOWERING SEAT #4
If you can find a 2004 or older seat mounting bracket from a 2K series, those brackets are lower. GQ, if you move the whole fender assy rearward, don't you have to move the fuel tank as well? There's no way I could move the fender on mine w/out shifting the gas tank.
Joel
   / LOWERING SEAT #5
I think the tear-down was just to get to the mounting bolts for the seat mounting frame.
I'll take a look at that if I ever have to pull the fenders. Or maybe a winter project :)
I believe what he proposes will work just fine.
Thanks!
-Larry
Joel
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2005 Ford Taurus SE Sedan (A51694)
2005 Ford Taurus...
2023 ALLMAND MAXI-POWER 15XR GENERATOR (A53843)
2023 ALLMAND...
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2000 Safari C-Series 425 40ft Panther Motorhome (A52377)
2000 Safari...
