Low-temperatue (Garage) thermostat - Wi-Fi enabled
   / Low-temperatue (Garage) thermostat - Wi-Fi enabled #1
tlj87
PA
JD 4700, Kubota BX2370-1, Kubota RTV1140CPX, Kubota F3060, Club Car Precedent
I am having portions of my barn/workshop insulated with spray foam and will be installing a propane-powered 75k BTU Reznor heater. I'd like to be able to monitor/control the temperate remotely. Everything that I've looked at has a minimum temperature setting of 50 deg. I'd like to be able to set the temp to 38-40 deg. F. What are you using?
If I can't find anything else, I could get one of those IP-enabled relays and connect it in line after a manual thermostat. It wouldn't provide temperature control but it would provide remote on/off capabilities.
Thanks.
   / Low-temperatue (Garage) thermostat - Wi-Fi enabled #2
If they haven't changed the Honeywell Wi-Fi stat go down to 40 deg. & there app is ok... even the lower end unit allows for remote temperature notifications & internet connection alerts & it is usually available at HD for like $80. They do need to be powered & will require a C wire, for constant power.
I Know the Aprilaire units can do it to but at a much high cost (also I believe the Ecobee3 & above can do 40deg also.... but at a price).... Honeywell will probably be one of the best option of the price & function... the RTH6580WF is the lower end one with Wi-Fi.
Also just a side note: You might want to check your Heater Manual / Specs most have multiple warnings stating the minimum temp it should be operated at to prevent damage to the heat exchanger. (many state 50deg min)
You will usually see a warning like:
Warning this heaters should not be used in an application where the heated space temperature is below XX- deg. Operating under low ambient conditions may cause condensation to form in the heat exchanger.
   / Low-temperatue (Garage) thermostat - Wi-Fi enabled #3
We have a Temp Stick to monitor a house remotely. You can set alerts for high and low temps as well as humidity to be sent to your phone or email. Very reliable and after a year of many alerts the battery still shows at 100%
   / Low-temperatue (Garage) thermostat - Wi-Fi enabled #4
I have an oil furnace in the shop with a basic thermostat but have the furnace plugged into a wifi outlet I can turn on or off at anytime or place or even use the timer or schedule.
   / Low-temperatue (Garage) thermostat - Wi-Fi enabled #5
I have three Filtrete 3m-50’s in the garage, on the cabin furnace and on the millivolt fireplace. It can go down to 40 degrees.
Other than a lightning strike killing one, I’ve never had a problem with any of them.
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
1986 Wisconsin 24' Tilt Deck Trailer (A52384)
1986 Wisconsin 24'...
1992 Effer 7600 2S Knuckleboom (A51692)
1992 Effer 7600 2S...
1965 Rodgers T/A Equipment Trailer (A53117)
1965 Rodgers T/A...
