"Low Tank Water" switch ?
   / "Low Tank Water" switch ? #1
bcarwell
Austin, Texas
Kabota 7500DT
Could somebody point me to the right type of 110VAC float switch(es) for turning on and off a basic 1 1/2 inch 10 GPM water pump for a 1000 Gallon tank, e.g. a switch that turns it the pump on when the water is low in the tank and off when its filled. I know there are plenty of "float" switches at Tractor Supply that sit at the top of the tank to turn off the pump when the tank is full. But what kind of switch senses when the water level is at the bottom to turn it on ? And is there a pair of switches in an assembly for both the "on" and "off" levels ? Or do you just kludge something together once you have the switches ?
Bob
   / "Low Tank Water" switch ? #2
On the sewage holding tank at the hotel I work for we have 4 switches, they are (from top to bottom):
1. Overflow switch - 2' from the top of the tank - Turns on an alarm when it is floating and the sewage is within 2' of the top of the pit
2. High level switch - 4' from the top of the tank - Turns on pump 2
3. Pump on switch - 4' from the top of the tank - Turns on pump 1
4. Lower switch - 2' from the bottom of the tank - Turns off the pumps when the tank is empty
I think that they are all "On when floating, Off when hanging" type float switches. They all go to a relay box which chooses which pump to turn on and when to do it
Aaron Z
   / "Low Tank Water" switch ? #3
I use these type switches for sewage pits. I use an on when down switch to turn the water supply to the building off if it water level in the sewage pit gets too high so the second floor idiots don't flood out the down stairs idiots. Oh , this on a 3 plex for college students. You can wire two floats to a relay and expand your range of pump up[ or down. Granger is an online source or a local plumbing/ pump supply.
I don't know anything about these "floating" switches and how they work. Do they ride along some sort of vertical pole like a piece of PVC and have a toggle switch toggled by stops at the top and bottom of the pole or what ? Do you have to kludge the assembly together yourself or are there inexpensive switch and pole assemblies you can buy ?
Bob
   / "Low Tank Water" switch ? #5
Some pond pump switches are floating type and I believe they have a mercury switch in the bulb that floats but I could be mistaken.
I know they just hang from the top or side of the pump depending on model.
   / "Low Tank Water" switch ? #6
They are a ball on a wire. You put a weight on the wire to set the travel of the float. It hangs in the pit on the wire. They were mercury switches but they have "saved us from the evil mercury". They are now mechanical. They have a ball that rocks back on a microswitch. They don't last as long as the old ones, but do better than anything I have come up with. I will have to do some thinking to get a wiring diagram on how to wire a double set up. A single can have a couple feet of pump down/up it will take a double if you want more . I just looked, Google Grainger float switch, several types will come up.
   / "Low Tank Water" switch ? #7
You can accomplish this with a single float switch. I have a water system that works exactly this way. Install a float switch tethered to a length of 1 1/2" PVC pipe that stands inside the tank:
Phoenix Pumps, Inc. - Goulds Float Switches
You need a NC/Normally Closed switch to turn on the pump when the tank level is low and shut it off when the tank is full.
Some switches of this type have very long cords. Where you attach it to the PVC and how much slack you let it hang by will give you enough travel to have the pump kick on when the tank is just under half full and kick off when it's full again.
   / "Low Tank Water" switch ? #8
as he said the single float switch is tethered in the tank. generally the tether is half the tank fluid level movement and tethered in the middle of the vertical fluid travel. (a 10' tall tank... tether is 4' long attached 5' down the side of the tank. this means the fluid level moves 8' leaving a foot at the bottom and a foot at the top) the switch can tell the difference between a vertical down position ( hanging by the tether out of the water....water to low) a horizontal position (floating on the surface) and standing on end (submerged underwater... water to high)
depending on the position of the switch (normal open vs normal closed) will dictate what the pump does at ether end of the float operation (aka will the pump come on when low off when high or vise versa shut off when low come on when high)
   / "Low Tank Water" switch ? #9
I am used to having a smaller diameter tank than it is tall. With piping and wiring to deal with a long cord on the float doesn't work for me. It can
get tangled up. In a water only tank the longer cord may be fine.
   / "Low Tank Water" switch ? #10
Float switches are rather clumsy and can get hung up or fail in repeated use. Better is a boiler low water cutoff. These have a single hole that a probe goes through and senses water. I'm setting one up now. When the water gets down below the probe it turns on the pump with a time delay relay that shuts off the pump after a set time that is enough to fill the tank. It only has one hole, no moving parts, all electrical is outside the tank.
My tank takes about 1/2 hour to completely fill, so I can set it up to come on and remain on for 20 minutes or so after the probe is covered.
This system also allows for various safeties or warnings if the pump fails, if you want them, such as a delay on warning light or buzzer that will tell you if the tank is not filling for some reason.
This technology is very reliable and is also used for boat bilge pumps in addition to boilers.
2016 Ford F-450 Ext. Cab 4x4 10FT Flatbed Truck (A51692)
2016 Ford F-450...
1999 Yamaha G16A Utility Cart (A52377)
1999 Yamaha G16A...
2017 FOREST RIVER 20 T/A CARGO TRAILER (A53843)
2017 FOREST RIVER...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2016 Ford F-750 Flatbed Truck (A52377)
2016 Ford F-750...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
