tractorhound
new to Massey Ferguson 165 late 1960's, but have completed a test drive on a used one with a fresh rebuild on engine. All the gears work but I noticed quite a lot more noise from transmission when in Low Range Reverse. (not there in Hi Range Reverse or in any other forward gear) ...any one have an idea if this is normal - or if it indicates a gear or bearing problem? Also any idea how much labour time it takes to split the tractor and put back together once transmission is repaired?
