Low power black smoke
   / Low power black smoke #1
picker2
kioti lb1914
I could use some help with my LB1914 blows black no power also I don't have a manual for my tractor so where do I start to look for the problem? Any help please. Alan
   / Low power black smoke #2
How many hours do you have on those injectors? Have you ever ran any injector cleaner through the fuel tank?
   / Low power black smoke #3
Check the air cleaner for blockage.
   / Low power black smoke #4
   / Low power black smoke #5
You're getting plenty of fuel and fuel needs air or else it will come out black from the exhaust. Most likely cause for insufficient air is a plugged air filter. May even have a nest of something in there.
Thanks for your response to my post. It's hard doing anything without a manual. I've tried to see what I could find out about the tractor,specs,drawings,and any diagrams.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
MI-T-M PRESSURE WASHER (A52472)
MI-T-M PRESSURE...
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
More info coming soon! (A50322)
More info coming...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
Kubota BX2230D (A47384)
Kubota BX2230D...
