LOW ON HYDRAULIC FLUID
   / LOW ON HYDRAULIC FLUID #1
stoyan79
Kubota L3700SU, TYM 4820CH
Hooked up new implement with large empty hydraulic hoses a month ago and apparently the fluid that filled the hoses emptied the tractor. :)
I put tractor on high gear today and floored the forward pedal, it was going good, but every 50 or so feet, it will bog down and almost stop. It will do it only on high gear where lots of flow is needed.
Got off the machine and checked the fluid level window - nothing to see.
Went on Amsoil.com and ordered a case of what was already in the machine.
Don't think machine can be damaged this way, but check your fluids guys.
In case you are wondering - this is the fluid I have been using:
https://myaccount.amsoil.com/shop/by-product/hydraulic-oil/synthetic-tractor-hydraulic-transmission-oil-sae-5w-30/?code=ATHQT-CA
It takes a bit over 6 gallons, which comes to about $200.
   / LOW ON HYDRAULIC FLUID #2
I kind of have a hunch that your tractor was low on hydraulic fluid BEFORE the implement was hooked up.
Example - 200 feet of 3/4" hose would hold 4.5 gallons of fluid. OR 100 feet of same hose holds 2.25 gallons.
It was a new log splitter with 2 hoses of about 6 feet each. I feel I am a quart or 2 low. Tractor operates normal, except high gear at 2K+ RPM with pedal to the floor.
2014 Chevrolet Cruze (A51694)
2014 Chevrolet...
2014 Ford Explorer Sport AWD SUV (A51694)
2014 Ford Explorer...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2019 BIG TEX GOOSENECK  TRI AXLE 34FT 2 CAR HAULER (A52576)
2019 BIG TEX...
