Oil & Fuel Low oil pressure alarm
   / Low oil pressure alarm #1
Rmosborn411
Texarkana TX
John Deere 3038
I have a fairly new John Deere 3038 compact tractor 2017. When I went out to start the tractor yesterday the low pressure light and the low coolant level light came on. Oil level and coolant are fine. Called dealer and they said the key switch or wiring harness may be loose. How do you access the the back of the key switch and wiring it seems to be lower than the side panel.
Any help or suggestions for the problem would be appreciated.
   / Low oil pressure alarm #2
:welcome: to TBN
Hopefully someone with experience can give you a lead on how to do that.
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
New Wolverine 3pt Receiver Hitch (A53002)
New Wolverine 3pt...
New/Unused 250 PVC Safety Traffic Cones (A51573)
New/Unused 250 PVC...
Crosley 10ft Hydraulic T/A Dump Trailer (A50323)
Crosley 10ft...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
