Low Hydraulic power/pressure
   / Low Hydraulic power/pressure #1
jbain
Prague, OK
JD 5065E and Kioti DK35
Hi, I have a 2000 DK35 with 1300 hours on it with Kioti loader. Have no hydraulic power to speak of. The FEL and 3Pt move but neither have any lifting capability.
I can't lift the front of the tractor off the ground as I have always been able to do.
I can only lift the TW60 brush hog about 5 inches where before I could lift it up to the stops.
I have changed the filter with a Kioti filter and the fluid level is good.
This happened while mowing a field I noticed I could not raise the mower up.
I have checked all connections where the FEL comes off the hydraulic system and all are tight.
Has my hydroulic pump gone out?
Thanks,
   / Low Hydraulic power/pressure #2
It is possible that your hydraulic pump has failed but at 1300 hours it isn't as likely as perhaps a bypass getting stuck or maybe a packing failure. Go to the hydraulics forum and search for " low pressure" there is a tremendous amount of information there that will help you troubleshoot to determine exactly where the problem lies. Many of the troubleshooting procedures cost only a few dollars in simple tools (hydraulic port caps, inexpensive pressure gage and male/female couplings).
   / Low Hydraulic power/pressure #3
If your hydraulics worked fine when you went out to mow and did not use them other than to lower the mower it's doubtful the relief valve is stuck open because that vavle has to be forced open when pressure reaches the max setting before anything can flow through it to get stuck.
Does your DK35 have rear remote (hydraulic couplers at rear of tractor)? If so look at the lever beside the seat marked A & B, make sure that lever is neutral not pulled into either A or B position. If it was/is locked in one position move it to neutral and try your loader or 3 point to see if power is back.
If the lever was locked in position and hydraulic power is not restored with lever in neutral that means it ran too long pumping oil through the relief valve and overheated the gear pump.
   / Low Hydraulic power/pressure #4
:welcome:
To the forum Jbain. You came to the right place to get answers.
Thanks for the reply. I'll check the remotes but don't think they are stuck as anytime I engage hydraulic I can normally hear the engine load a little. I did raise and lower the FEL to miss things such as fences while I was mowing. I just out of curiosity got a price on a new hydraulic pump $1167 so will be examining this problem very closely as to not have to purchase one. I ordered a pressure gauge and coupler so I can check the pressure.
Ok, I checked the pressure on the hydraulic system and at the remotes it is 1000 PSIG at 2400 RPM. I pulled the pressure relief valve out and it seemed to be okay as it is a very heavy spring so don't think it could be bad.
This is leading to the hydraulic pump as the culprit.
Anyone got any other ideas?
   / Low Hydraulic power/pressure #8
Is your relief valve adjustable?
I don't know do you think the tension on the spring would lesson over time to the extent that the pressure would be off 1400#?
In the service manual it says it has shims to adjust the spring tension.
2016 Bobcat S850 (A50120)
2016 Bobcat S850...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
2023 John Deere 8R410 MFWD Tractor (A52748)
2023 John Deere...
Sunflower 1435-30 Cushion Flex Disc (A52349)
Sunflower 1435-30...
2014 Ford F-250 Extended Cab Knapheide Service Truck (A50323)
2014 Ford F-250...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
