Dec 20, 2009 / Low hydraulic fluid in Ford 860 with FEL #1 B botemout Bronze Member Joined May 6, 2009 Messages 51 Location Upstate NY Tractor 1957 Ford 860 Should be removed; can't find way in the web site to do that ... Last edited: Dec 20, 2009
Dec 20, 2009 / Low hydraulic fluid in Ford 860 with FEL #2 J_J Super Star Member Joined Sep 6, 2003 Messages 18,952 Location JACKSONVILLE, FL Tractor Power-Trac 1445, KUBOTA B-9200HST Select edit on the post you want to delete. Select delete post, you can give a reason or not give reason, then select delete post. After you do that, I will delete my post.
