low hp hydro - is it worth it?
   / low hp hydro - is it worth it? #1
GaryS
franklin park, pa
Kubota L3901 & LA525
We've just finished building the house, I need a lawn tractor and I'm really budget constrained. So, I think I've decided to get a low cost lawn tractor. I'm looking at the 20hp Craftsman tractors which I can get gear or hydro. I know that on a diesel tractor, you loose HP to the hydro and I imagine that's the case here too. I don't mind gear&shifting especially if it means longer life and more hp - but are there gotchas that I'm not aware of? Can you shift while the cutting deck is engaged?
   / low hp hydro - is it worth it? #2
My opinion, gear or hydro depends somewhat on the use. I have a DYT4000 with a kohler Command 25 and a Hydro Gear sealed unit. The tranny always has the torque to spin the tires when engine rpm's are half throttle or better. However a small hydro may not be the best choice for severe use, ie.steep grades, pulling slingers, trailer sprayers and aeroators. I basically killed my tranny in 4 years.
Now the rest of the story, I would buy the exact same piece again. The ability to seamlessly change speed as conditions require for the last 4 years and the amount of time I think it has saved is worth the new $400 tranny I just put in it.
There is no directional interlock on the one I have. Two pedal setup, push and go.
Do not know if i answered your question, just a few observations to consider.
   / low hp hydro - is it worth it? #3
I think if you worry about a loss of hp with a hydro on a riding mower, you're wasting your time worrying. Obviously there are people who still prefer the gear models or they wouldn't still be selling them, but for me, personally, there's no way I'd even consider a gear model riding mower. Tractors for farm use are another matter.
   / low hp hydro - is it worth it? #4
20HP is so rediculously overpowered dont worry about the power wasted by the hydro.
If you are losing 2HP to the hydro on a 12HP tractor, its something to think about. If you are lsing 2HP on a 20HP (that only needs 14-16 to move the deck) then dont lose sleep.
Other than that what Dieselsmoke and Bird said, get whatever suits you the best. If you are just mowing or doing light work, get hydro. If you want to do work (towing, groudn engaging) get gear.
Bird, in the Westwood lineup (British made tractor mower, popular around here) only the smallest (12HP 36") tractor has the option of gear and hydro, all the others are hydro only. Very few, if any, tractors come with gear now here. I'm still not convinced about hydro, I like the variable speed, but it just hasnt proved itself to be string enough for me, and I dont like the fact that the wheels arent connected directly to the drive. I would love to have a hydro for a week to try it out, I dont think it would last the week here, but I would love to be proved wrong, so I can buy one! :D
   / low hp hydro - is it worth it? #5
Mith, I think you're wrong, but can't prove it.:D
   / low hp hydro - is it worth it? #6
Bird, if you put up half the money, thinking would be enough. Bit proving it is the minimum for me to buy all out ;) :D
   / low hp hydro - is it worth it? #7
Ive had good luck with most of my Hydrostatic and Gear mowers.
Hydrostatic
2001 JD 425- Ran a Front loader, mowed 3 acres- Sold with 350 hours, no issues
1996 JD 445- Ran front loader for 300 hours, mowed 3 acres- Sold with 1400 hours, no issues
1993 Wheel Horse 416-H- 723 hours on it, Used it this season to plow 1/3 acre, not a problem
1988 JD 316- 1300 hours on it, punished its whole life before I got it, hydro is flawless
GEAR
1962 WheelHorse 702- 3spd+Rev. Pulls like he11, lifts the front tire 2 feet off the ground, quiet.
1988 WheeHorse 310-8 8speed- 4 gears High 4 Gears Low- after about 1000 hours, it has a faint whine in 3rd High...but its still precise and strong. So strong I dumped almost 300 in rebuilding the Orginal Kohler
198X- Cub Cadet 1200. 3spd+ Reverse- No problmes except for driveshaft failure, but that was user error.
The hydros are nice, nifty, but you dont get the "feel" like you do with a gearbox.
The gears are nice trannys, strong, but you only have 3 or 6 options at a give engine speed.
We had a Craftsman Hydro for a couple of year around 1996 or so. It lasted 2 years before it started to howl loudly and lose power. On the flip side, Ive seen more than a handful of the inexpensive gear drives fail in more than one way.
To each their own I guess.
   / low hp hydro - is it worth it? #8
I've been running a hydro on my JD lawn tractor. It is seven years old and going strong. I thrash it, too. I use it to pull a trailer that I've (over) loaded down with wood, dirt, rocks. I always run out of traction before running out of power, and the thing only has a 16hp engine.
Whenever I have to use a gear drive lawn mower I hate it. You either get a jerky start or you're stuck going too slow once you get going. I usually wind up starting off in a lower gear and then jam the thing into a higher gear, which makes me cringe at the noise...
   / low hp hydro - is it worth it? #9
Ive gotten pretty good at speed shifting my 8 speed. It is an H patters like a car. Trickiest shift is 1st to 2nd.
What is fun is doing it with a load, up an incline, without losing momentum...>:) haha.
Ive seen some pretty nasty failure from people shifting on the go on a non shift on the go..teeth stripped, shafts twisted, cases broken...
What model JD you got?
Tommy-
   / low hp hydro - is it worth it? #10
Just about everything has gone the way of hydro drive now, but I preferred the good gear drives. JD 214 had a variator lever for its gear drive that (when it worked, it was one of the tractor's weak points) gave a little speed variation in each of the gears.
The hydros are easier to use with no clutching, but they will speed up and slow down a bit on inclines and declines where the gear drives would stay a steady speed. I think I mowed with the 214 in 3rd, and it would stay the same forward speed and needed no input to mow long straightaways even with hills. In other words, you could fall asleep on it :) Even with small hills, you have to stay awake when mowing with a hydro, just no gear shifting or clutching. On the 214, I could, "float," between gears without stopping or clutching, but you were supposed to stop and start with it in one of the gears.
Most of the older gear drives and cast iron hydros were indestructible. Many of the small aluminum body hydros used in the lower cost tractors today will not stand up to a lot of abuse.
-Fordlords-
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
2007 Amkus Rescue System (A53421)
2007 Amkus Rescue...
11ft S/A Fuel Tank Trailer Frame (A51691)
11ft S/A Fuel Tank...
RIDGID POWER DRIVE/HAND HELD THREADER (A53843)
RIDGID POWER...
2015 Ford F-550 Ext. Cab Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
2004 Ford F-250 Liftmoore 2,700 LB Crane Service Truck (A53422)
2004 Ford F-250...
