Low hour LX4500: A bad idea?
   / Low hour LX4500: A bad idea? #1
Shrew_Gardens
BCS 749
I have an older “starter” tractor (NH tc29d) for landscaping and general gardening chores and have a plan, after I finish some projects at home, to use it to repair and build roads in the woodlot (100 acre hardwood) as well as bring out wood.
I can’t complain about it so far but I’ve been wanting a BH and foresee a bit more power wouldn’t hurt either, especially in the woods.
I have found advertised a 2014 LX4500 w/ BH with just 70 hrs, described as paint weathered but mechanically perfect. I have a hunch I can get it for under $30k but does this seem concerning for a lemon?
I assume it is tier 4 …I have no experience with the newer rigs, the NH is my 1st tractor and 1st diesel.
Wanted to see if I could get the thoughts of some of you with more experience so I don’t show up any more unprepared than necessary.
Note I edited production year, seems to be 2014, not 16
   / Low hour LX4500: A bad idea? #2
I have about 700 hours on my lx4500, I bought mine new in the summer of 2012. It is a tier III/interim tier IV engine which is desirable if you don't like DEF or regen. This model came out just before those inconveniences became common.
Generally I really like the tractor and the 4tnv88 engine is very well proven in lots of platforms.
I garage mine usually so I can't really speak to "leaving it outside in the weather" issues.
The only major issue I had, and I was told by the dealer that it has occurred on others, was a small screen internal to the hydraulic system can get loose and jam the three-point lift valve so it doesn't lift. Mine was repaired under warranty but it would probably cost about $1000 or so to fix out of pocket.
All other things considered, I've been pretty happy with the LX4500 performance, reliability, and handling.
   / Low hour LX4500: A bad idea? #3
I don't know the tractor but that seems really low hours for an eleven year old tractor. You might inquire how that happened. I believe 2014 or later is when they went to tier four. If it's got a DPF that will tell the tale.
Thank you both for the replies! I was hoping there’d be a little more presence here for this series of tractors.
I found a 2nd ad that describes it as a demo unit for a local water utility, which I suppose would explain things in part.
2000 Trail King TK70DGHT 45 Ton 44FT. Step Deck T/A Hydraulic Tail Trailer (A48081)
2000 Trail King...
2016 POLARIS RANGER ETX EFI 00HC RTV (A50459)
2016 POLARIS...
UNUSED MOWERKING SKID STEER AUGER SET (A50460)
UNUSED MOWERKING...
ASV Posi Tool Backhoe Quick Attach (A48837)
ASV Posi Tool...
2016 FORD F-350 SUPER DUTY XL FLATBED TRUCK (A50459)
2016 FORD F-350...
2011 Ford Escape XLT SUV (A48082)
2011 Ford Escape...
