Low cost method to get hydraulics to rear.
   / Low cost method to get hydraulics to rear. #1
Nlight
Bronze Member
Kiel, WI
Bobcat CT235
I have a CT235, with no rear (or front) hydraulics. This fall I will need one set of hydraulics on the rear to operate a small no till drill. As this will be a one time need I really don't want to spend the money to "do it right", and install the rear remote. I think that cost is like $800.00. Is there anything wrong with removing the lines to the bucket tilt function at the loader valve and then extending that function to the rear via hoses and couplers? I expect the cost would be pretty reasonable for the two hoses and four couplers needed.
Any other suggestions?
   / Low cost method to get hydraulics to rear. #2
That should work.
   / Low cost method to get hydraulics to rear. #3
Ask Rick Wallace for the kit. It's only about $200-300 and then you have real rear remotes. Installing them is about a 2 difficulty on the 10 scale. (That's what I did) I'd guess it'd almost be easier to do yourself than your Hillbilly engineered way. But I gotta respect the Hillbilly engineering though
Good Luck
2011 FREIGHTLINER M2 26FT BOX TRUCK (A50505)
2011 FREIGHTLINER...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
John Deere 2700 5 Bottom Plow (A50514)
John Deere 2700 5...
CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
CATERPILLAR D6T...
