Low Center of Gravity ?
   / Low Center of Gravity ? #1
PhilG327
Bronze Member
La Farge, WI
BCS 852
I am looking for advice on a riding mower with a VERY low center of gravity. I have looked at a few zero-turn mowers, but most are not very low and regardless the prices are way beyond my budget. I have grape vines, apple and fruit trees and hazelnuts planted on a slope that averages around 20 degrees and with the rows planted along the slope my old Troy-Bilt riding mower just feels unsafe. I'm getting too old to do it all with a BCS anymore.
Can anyone recommend a used brand/model (maybe under $1500) that might do the job ? Either zero-turn or conventional ?
Thank you !
   / Low Center of Gravity ? #2
I don't know how expensive they are and I don't have any experience with them but IMO this is what I would suggest. Grillo Climber Range
Exactly ! The video clip on that web site looks a lot like what I need. I expect unless I could find a used one a new one would be impossible. Thanks for the information as I have never seen or heard of these mowers. We do have a Grillo dealer here in Wisconsin so it might be worth asking.
   / Low Center of Gravity ? #4
Thank you !
The Husqvarna R322T AWD is really good on slopes because of it's all wheel drive.
It has a pretty low center of gravity, which also means it does not have much ground clearance either.
Probably won't find many used unit around though, and new units go for $5300.
There is also a flail mower attachment available which could handle the more demanding mowing jobs, if you needed heavier duty mowing.
   / Low Center of Gravity ? #5
Might be difficult finding something adequate in that price range. I have a JD LT180 which is about 11 years old. I mow on some pretty steep slopes......only go down for the most part. I run chains almost all year due to our wet weather. Someday....when I have to replace the mower.....I will go all wheel drive. Good luck in your search.
   / Low Center of Gravity ? #7
What bcs do you have? Maybe get a sulky?
   / Low Center of Gravity ? #8
Before you give up on the Troy-Bilt you may want to try filling the tires which would lower it's center of gravity. You should be able to do that really cheap if you can find a local garage that will give you used antifreeze.
   / Low Center of Gravity ? #9
I've seen dual rear tires on deere 425 and 445s
John Deere 5075E (A44501)
John Deere 5075E...
Freightliner Truck (A42203)
Freightliner Truck...
2007 CAT 308C Excavator (A42203)
2007 CAT 308C...
2017 FREIGHTLINER CASCADIA (A45046)
2017 FREIGHTLINER...
2014 Ford F-150 Crew Cab Pickup Truck (A44572)
2014 Ford F-150...
CATERPILLAR C12 (A45046)
CATERPILLAR C12...
