Low brake fluid indicator on dashboard on TN65
   / Low brake fluid indicator on dashboard on TN65 #1
Chuck_Lind
Mahaffey, Pa.
2000 New Holland TN65 & 1956 John Deere 50
For the last couple of days, I noticed the low brake fluid indicator light flickering. First...to the manual to read up on troubleshooting. As one might expect, low brake fluid.
Removed the cap from the brake fluid reservoir only to find out it's nearly to the "max' level. Added more brake fluid as a safety measure. Next...check below the engine compartment for brake fluide leaks, under the tractor, etc.
Still get the flickering low brake fluid indictor light.
Possibly a faulty sensor? Anyone had this problem?
BTW...had the same problem on a faulty oil pressure sensor.
   / Low brake fluid indicator on dashboard on TN65 #2
Some thoughts:
It's not uncommon for the fluid level to drop a little as the brake discs and plates mate to each other in the first hours of operation. This could be anywhere from 50 to 200 hours or more depending on conditions and operating style.
It is not uncommon for the reservior to need to be slightly over the 'MAX' line to keep the darn light off.
It isn't a very sophisticated float switch and they can hang up or fail.
RickB said:
Some thoughts:
You're not kidding, Rick. The whole plastic reservior, cap, hoses, mounting seems like something invented by Mickey Mouse.
Been doing some backblade work today and the light doesn't come on...yet.
   / Low brake fluid indicator on dashboard on TN65 #4
I had the same thing happen on my TN75 - the connector on top of the cap had been pulled apart slightly. Pushed it back together and solved the problem
There has been many posts regarding electrical problems with NH tractors - myself included.
Just one more item to check.
However...as with any tractor/truck/automobile built today, there's so much electronic devices/sensors that no wonder something goes wrong. Case in point: My '05 Chevy Silverado is going back to the dealer for it's 3rd electronic module that controls the window lifts, keyless entry, etc. And it only has 15,000 miles on it.
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
Ford Pickup NR (A50323)
Ford Pickup NR...
2019 FREIGHTLINER M2 26FT BOX TRUCK (A52577)
2019 FREIGHTLINER...
1986 ASPT 30ft S/A Pole Trailer (A51692)
1986 ASPT 30ft S/A...
2019 Doosan LCV6W Towable LED Light Tower (A51691)
2019 Doosan LCV6W...
2010 Freightliner M2 106 Crew Cab Dump Truck, VIN # 1FVAC2BS5ADAP9253 (A51572)
2010 Freightliner...
