Love joy connector life
   / Love joy connector life #1
BobRip
Elite Member
Powhatan Va.
2000 Power Trac 422
I think that is the right term for what connects the pumps to the engine. I have about 1100 hours on my PT422 and have not had any problems with these except the hex screw loosens up and I don't usually retighten them. Does anyone have an idea of the expected life of these? Should we use Locktite on the hex screws?
   / Love joy connector life #2
Loctite wont hurt
Genuine Lovejoys can and generally do last a LONG time.
   / Love joy connector life #3
Yes, do tighten the screws.
Well aligned Lovejoys can last a long time. Slight misalignments can reduce the lifetime to a tens of hours.
All the best,
Peter
Thanks.
   / Love joy connector life #5
My brand new love joy is shot after about 15 minutes of use on a log splitter. Mounting bracket from pump to motor must not be aligned properly since its homemade. The rubber got all chewed up
   / Love joy connector life #6
15 minutes is a pretty good indication of not being aligned well...
There are a bunch of instructions and videos at the LoveJoy that include what the tolerable misalignments are for each type of connector.
It can be a bit fiddly, but when you get it right, it is done for a long time.
Don't forget to check the play on the two shafts before you install the coupler. Bad bearings or warped shafts will also eat Lovejoy connectors up.
All the best,
Peter
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
Komatsu 330 Excavator (A51573)
Komatsu 330...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
HARDEE RD72M LOT NUMBER 158 (A53084)
HARDEE RD72M LOT...
2007 International 7600 Tandem Truck, VIN # 1HSWYAHR37J478209 (A51572)
2007 International...
