LOUD 3 point lift -- Kubota 6100E
   / LOUD 3 point lift -- Kubota 6100E #1
tcnjdeluca
Hello,
The 3 point lift on my little Kubota 6100E is very loud. I honestly did not think too much of this at first because otherwise it lifts up my rear blade fine. I am new to tractors but I am finding out that 3 point lifts should not make any noise at all let alone a loud screeching sound.
The only time it does not make the sound is at low idle when it is first started.
I am currently on the process of clearing out hydraulic fluid that was very contaminated with moisture. After the first change though the sound remains unchanged. Could this cause the noise? I have been reading about "pressure relief valves" but I am not clear on where it is located or how I can check it.
I do not want to spend a lot of money on this cause the lift does work, but if can take care of it easily I would like to. Thanks for any advice.
Dan
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2010 JOHN DEERE 4730 LOT IDENTIFIER 157 (A53084)
2010 JOHN DEERE...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
4' X 8' X 1/8" THICK DIAMOND PLATE STEEL SHEETS (A51247)
4' X 8' X 1/8"...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
