tcnjdeluca
- Joined
- Jan 13, 2011
- Messages
- 36
Hello,
The 3 point lift on my little Kubota 6100E is very loud. I honestly did not think too much of this at first because otherwise it lifts up my rear blade fine. I am new to tractors but I am finding out that 3 point lifts should not make any noise at all let alone a loud screeching sound.
The only time it does not make the sound is at low idle when it is first started.
I am currently on the process of clearing out hydraulic fluid that was very contaminated with moisture. After the first change though the sound remains unchanged. Could this cause the noise? I have been reading about "pressure relief valves" but I am not clear on where it is located or how I can check it.
I do not want to spend a lot of money on this cause the lift does work, but if can take care of it easily I would like to. Thanks for any advice.
Dan
Dan
