Lost some pipes last night
   / Lost some pipes last night #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Well.. I guess the sustained 26' weather last night and high winds were just too much. I lost some pipeing in the back of my pasture. Mainly I lost 2 spighots, and the piping between them.. probably 35' and a couple risers in all.. plus the valves on those risers popped. Water run to the barn and pasture trough must have been burried just a tad deeper.
I took off work at 3pm today and went home with a bag full of unions, t's and elbows, and other assorted fittings, and a new can of pipe dope. Got out my trusty ratcheting pipe cutter a grub hoe and shovel and headed out to the back of the pasture. Took me from 3:30 to7pm to get the lines uncovered in the broke area, and new ones in, new risers and valves, and then insulate them. Pressure tested fine. I ran out of time an light and turned the water back off to the pasture after all the auto waterer's filled up, and tyhen drained the lines as we are sopposed to get just as cold again tonight.. and I don't have the line covered back up.. it's just setting naked inthe trench. I think I will also use the fel to add a small mound of dirt on top of the burried line down the fence line to try to keep it from popping again.
What a day. my backs killing me.. I had to feed the animals via tractor lamps.. My trust 33hp 6v flashlight ( ford 660 ) was quite up to the job.
I'm beat!
Soundguy
   / Lost some pipes last night #2
Wow, I'm impressed that central FL got that cold! (As I sit here feeding wood into the stove against the minus 18 outside.) My inlaws moved down there to escape the cold; they must be miserable right about now!
Pete
2025 SDLL30 Mini Stand-On Track Loader Skid Steer (A53421)
2025 SDLL30 Mini...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2019 GEHL R105 WHEELED SKID STEER (A51242)
2019 GEHL R105...
2000 Sterling L9513 Winch Truck (A55218)
2000 Sterling...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
