Lost FWD on BX22
   / Lost FWD on BX22 #1
JEDsBX22
Kubota BX22
I’ve spent many hours reading posts here and learning about tractors. This is my first post and of course it would have to be about a problem!
I have a BX22 with about 250 hours on it. I’ve been very good about maintenance intervals and such.
The tractor has lost the ability to operate in FWD. I was mowing with the FWD lever forward (steep hills) for about an hour. I noticed the problem when I went to back up a hill and the rear wheels just spun. There was no noise or any indications at all of problems before this. Back at my garage I noticed that the front axle fill plug had come loose a couple of turns, with UDT leakage around the plug/axle housing. I have no idea how long the plug had been loose.
I topped off the axle with UDT (required less than a pint to reach the top fill slot in dipstick), firmly tightened the plug and I still do not have FWD.
Has anyone else had this problem? I hate taking it to the dealer without at least trying to fix it first.
   / Lost FWD on BX22
Holy Smokes!
I took off the mid-mount mower and put the tractor on ramps. The problem is painfully obvious. The U-joint connecting the drive shafts is completely missing! I walked my whole yard searching the steepest areas and all around where I first noticed losing the FWD… Nothing.
Then on a hunch, I searched in the loose grass clippings on top of my dismounted mid mount mower – and there it was. I am just glad it did not get jammed in the belts and pulleys.
Guess I’ll have to find a new sheer pin.
   / Lost FWD on BX22 #3
Glad to hear you found the reason for the problem, and the parts, without having any further damage.
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2013 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2013 FORD F-150 XL...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A53472)
2019 Energreen EVO...
New Land Honor 3'' Semi-Trash Water Pump (A53002)
New Land Honor 3''...
