lost all the hyd fluid, now wont start 580m
   / lost all the hyd fluid, now wont start 580m #1
tbergman
Tahlequah, Oklahoma
Branson, Kubota, and Case
So a few days ago, Betsy (my 580M Series II) was running fine. During the day I noticed the left stabilizer cylinder was leaking ( a drip every few seconds), so I decided to take her to the shop to get the cylinder repacked and also to have a couple of slow leaks addressed at the same time. I took her down to my dirt quarry and loaded up a few trailers of fill dirt, all with no issues. Left her for a couple of days and yesterday, noticed the stabilizer was on the ground. Turned the key and absolutely noting; no click, nada. Then I checked the hyd fluid level and it was completely empty. I was not in position to try and jump her, and it occurred to me that she might have a safety switch that shut power off when the hyd fluid is dry. Is that the case?
I plan to add hyd fluid and jump to start if necessary then head to the shop asap when I get back to her early next week. Would be great if all I need to do is fill up the hyd reservoir and she will start right up...one can hope.
   / lost all the hyd fluid, now wont start 580m #2
Surely you mean it's just low on fluid not "dry". If dry, where did 25+ gallons of hydraulic oil leak out? I'm guessing either the battery is dead or you have a bad cable connection.
I doubt there would be a low oil switch that would completely stop all electrical power.
   / lost all the hyd fluid, now wont start 580m #3
I'll 2nd that. Also, even if you cut both lines to a cylinder you are only going to loose what's in the lines up to the valve & maybe whats in the cylinder. Only a fraction of the total volume in the sump.
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
2014 Nissan Rogue Select SUV (A51694)
2014 Nissan Rogue...
FRONTIER FAV20 LOT IDENTIFIER 65 (A53084)
FRONTIER FAV20 LOT...
ROME GK-14 LOT IDENTIFIER 118 (A53084)
ROME GK-14 LOT...
UNUSED HURRICANE 20' X 20' ALL-STEEL CARPORT (A51248)
UNUSED HURRICANE...
