Sassi
June 1st I went to hose off my L3240 and saw some oil streams in the dust, on both sides of the cowling in the vicinity of the location where the four bolts on each side go into the engine/frame that connect the FEL to the tractor. I checked the engine oil. It was full. I checked the Kubota UDT fluid and got a shock. It did not show any oil on the dipstick. June 2nd I went and bought 2.5 gallons of Kubota UDT fluid. I measured the fluid into a quart container and began to fill up the tractor. It took 6 quarts of Kubota UDT fluid to bring the level up to normal on the dipstick. I forgot to mention that this is a new Kubota, and that I have only put 19 hours on it since I bought it.
The shelter where I keep this tractor has a dirt floor. I put down plastic under the tractor. For two days now I have gone out cranked the tractor, let it warm up and have manipulated the FEL and three point hitch controls to see if I can find any drips, or visual leaks any place. After several hours of this spread over two days I still cannot find anything. The nearest Kubota dealer is seven miles away. It is a lot cheaper for me to just drive the tractor to the dealer. Before I go and drive it to this dealer I have scheduled a mechanic who works for this dealer to come by after he gets off work and to see what he can find out. He will be by probably on this Thursday. Yes I have to pay him out of pocket for this visit since he is doing it on his own time after he gets off work. I would rather do this and have him check it before I drive it to the dealer. Maybe it is something simple that he can fix. Anyone else had any similar issues to what I am describing here?
