Loss of power
   / Loss of power #1
dhabicht1
I have a Husqavarna YTH1848XP with a Kawasaki 18 hp v-twin. Under no load it seems to run and idle fine but as soon as I hit the button to turn the mower deck on it almost stalls. I'm guesing this is due to a problem with the deck. Everything seems to turn as it should and the belts are OK. Can anyone reccomend any tips or things to try.
   / Loss of power #2
Try turning the blades by hand to see if it turns easy or not( engine off and all that good stuff), you may have a bad spindel bearing or ideler bearing.
   / Loss of power #3
I would change the fuel filter first. Run some carb cleaner thru it. I do not know this engine, but it sounds like it is running lean. Is there a high speed and low speed fuel adjustment on it? Try to adjust if possible. Also, if it has a fuel pump, check it for volume.
   / Loss of power #4
You may have a coil going bad. I had that problem with my 23hp KAW last year. It seemed to idle fine but the minute I put a load on the motor ( either engage the deck or drive in any direction ), the engine would lose power and go nowhere. Try undoing one spark plug wire at a time. If motor dies then the other coil is bad. Good luck.
Tiny
   / Loss of power #5
Make sure you stand in a puddle of water while working w/ the spark plug wires.
Ha, seriously though, i think unscrewing the spark plug wires on a running engine might be somewhat 'problematic.' How would you do this w/o seriously damaging yourself?
   / Loss of power #6
Didn't KAw motors have an ignition problem? I think I remember a thread about them.
   / Loss of power #7
Mike5252,
Just grabbing the spark plug wire at the boot and pulling off of the plug should not do any damage to yourself the the engine provided you don't let it arc to anything. If fearful of your safety put on some leather gloves before doing it.
dqdave1,
I think I remember the same thread but couldn't find it. Was at dealer today getting parts and was told by parts guy that they sell quite a few coils for KAW motors. Probably their most popular common item next to plugs and air and fuel filters.
RYOBI 40V 15" ELECTRIC WEED EATER (A51248)
RYOBI 40V 15"...
16ft Heavy Duty Aluminum Ramps (A53472)
16ft Heavy Duty...
2024 BOBCAT T770 SKID STEER (A51246)
2024 BOBCAT T770...
MURRAY 22" GAS PUSH MOWER (A51248)
MURRAY 22" GAS...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
2022 COSEN INTERNATIONAL INC V-1822 BAND SAW (A51248)
2022 COSEN...
