Oil & Fuel loss of power
   / loss of power #1
joed3320
Hinesburg,VT
Johndeere
3320 seems like the top end power is not there.I notice it when I plow snow or shift in high range and go down the road and come to a little hill.I buy off road diesel I was told sometimes they add something to the fuel in cold weather which could effect my power.Is there a safe additive to put in the tank to clean and add power,only have 560 hours less than two years old.Has anybody had issues like this?
   / loss of power #2
I add cetane boost in the winter like this: Power Service. Good idea to check that your intake is clear, no critters leaving stuff behind or clogged filters.
   / loss of power #3
How long has it been since a fuel filter change? (Little or no black smoke under load). How about a air filter change? (Black smoke) The obvious first. How cold is it where you are? It could be fuel gelling / waxing up the filter.
   / loss of power
complete service was done at 410hrs,the temp might be a thought the tractor is stored out side I have a heat houser and let it warm up for 5 minutes or so but the fuel would still be cold at under 20* adverage
   / loss of power #5
My 3320 (new to me this fall) did the same thing this late fall when I had to run it down the road to mow some property I had just purchased. Worked fine while mowing but when I would go out on the road in high range, as soon as I came to a grade, the speed would bleed off rapidly. 14-15 MPH on level road. It was too warm then for gelling.
   / loss of power #6
Hydro I'm assuming? Are you empty or with heavy implements?
My 4600 hydro does the same thing in C range. The more you depress the pedel down going up hill, the rpm's drop. Find the sweet spot in the pedal between power and speed.
Chuck D.
   / loss of power #7
I had the same problem with my 3720 all was fine mowing in B then when to C and up the drive hill and it struggled. I read on this site that someone else had this problem and someone suggested to make sure the tractor is not in LoadMatch mode.
   / loss of power
I put 4oz of Cetane Boost and I will get out my book to check on load match I haven't worked with that yet.I do feel better others with larger tractors in C have similar issues,all I could think about is big$$$ thanks for sharing
1997 John Deere 8100 MFWD Tractor (A52748)
1997 John Deere...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
378803 (A51573)
378803 (A51573)
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
