Oil & Fuel Losing power, JD 4510
   / Losing power, JD 4510 #1
Kevin JD4510
asheboro, nc
John Deere 4510
I have a 2003 JD 4510 utility tractor and am having an issue with power loss. When mowing with a 5" BH, after about 30 min, the engine will basically fall over and stall. I let it sit for a minute and then start again. It will start slowly and eventually come back up to the correct RPM depending on when the throttle is. Runs normally for about 3-5 min and does it again. When sitting still, under no load, the engine seems to run normally as best as I can tell. Issue is generally after it is up to temp and under a load. It seems that it has a loss of fuel or possibly an air intrusion issue. I have checked all rubber hoses for blockages and found none. The fuel bowl does not lose any fuel, or fill with air. While running I can crack the injector lines at the pump and the engine falters as it should. Any advise out there, any would be greatly appreciated.
   / Losing power, JD 4510 #2
:welcome: to TBN
Sure sounds like short on fuel... algae in the tank, debris in the tank, plugged fuel line, cap vent plugged, filter needs changing, etc.
Any of these sound possible?
   / Losing power, JD 4510 #3
Ditto what beenthere stated.
2002 Blue Bird F131612 Bus (A51692)
2002 Blue Bird...
2021 Hyundai Elantra SEL Sedan (A50324)
2021 Hyundai...
Pallet Fees (A50775)
2019 John Deere TX Gator Utility Cart (A50322)
2019 John Deere TX...
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A50322)
2021 ASV RT-135...
