Losing power and stalling
   / Losing power and stalling #1
TemporaryKubotaOwnerMark
Veteran Member
TimBuckToo
Gone
Yesterday my BX25 lost power while my son was carrying a load of gravel in the bucket. He dumped the load and limped it up near the house to check it out. It would barely move. We replaced the fuel filter, but that has not helped. He attempted to follow the bleeding procedure, but it died after about 5 seconds. Started it up, and it ran for the required 30 seconds, but roughly, then he shut it off. Started again and it died. It will rev up if the throttle is cranked up, but then will stumble and the RPMs go down, and sometimes it dies.
The old filter was installed in April 15 (the PO marked the date on the filter - good man!). I can see there is black crud in it, so may be it was a bit past due. We've been doing trenching work so there's been no shortage of dust. Air filter is okay. Could stand to be blown out a bit.
Fuel is off-road, run through a 10 micron filter and a moisture block filter before going in the tank. We don't run it dry.
I'm new to diesels and tractors. Any suggestions would be welcome.
   / Losing power and stalling #2
It's very likely a fuel related issue. Does it smoke when it starts to die?
Not that I have noticed. Yeah, I'm thinking fuel, too, hence the filter replacement.
I'm hoping it's not the injection pump, but I don't know how to go about testing anything diesel. I do my own work on my cars, but they are gassers.
   / Losing power and stalling #4
Original problem was likely water in the fuel.
Current problem is probably related to bleeding the system.
Follow the bleed procedure again.
   / Losing power and stalling #5
I had issue in one of mine much like this earlier this year. It was also off road fuel pumped through water blocker but it had enough water in the fuel did about the same thing. I still think you have water in there. My Kubota's have a clear water separator where you can see if there is water in the fuel (separated out) if your does empty it and it will not hurt to pull the new filter off and pour it out and reinstall. If you will fill those before you reinstall you may not have to bleed the system. On my Kubota's have never had to bleed a system when I fill the filters before installing new ones. Then I crank the tractor and give it a good rpm.
   / Losing power and stalling #6
Water can still build up over time in the fuel tank of the tractor. Water settles to the low point and collects in the filter housing. Which is why alot of them (like my old fords) have a drain on the bottom of each filter unit. And on my kubota is a clear plastic housing that can easily be removed and rinsed out.
   / Losing power and stalling #7
Drain some fuel out of the bottom of the tank to see what you get. If it's good just keep proving the fuel supply as you go along to the filter and then the injection pump. If good bleed the pump.
There are times when the tank screen gets plugged up or bacteria or other gunk accumulates in the tank.
   / Losing power and stalling #8
I agree with the other suggestions, but wanted to throw in my two cents. The "gravity flow" check is a good idea to do as well. This check will help you determine if there's stuff plugging the tank screen, like Egon said above.
Pull the hose off of the filter housing, if you can, then see if the fuel flows freely or dribbles out.
   / Losing power and stalling #9
I could be wrong, but don't they have 2 filters on them?
   / Losing power and stalling #10
The black gunk in the filter reminds me of some past problems with a bx, apparently some organic matter got into the tank (leaves etc.), broke down and clogged the outlet. Might want to look into the filler opening at the outlet, provided the fuel level is low enough.
Also the electric lift pump might be an area to investigate.
1041 (A50459)
1041 (A50459)
2009 Lee-Boy 8510HD Conveyer Feed paver (A51039)
2009 Lee-Boy...
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
Lift Station Pumps (A49461)
Lift Station Pumps...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
