Losing Forward power on Hydrostatic
   / Losing Forward power on Hydrostatic #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
I lost power in all 3 speeds just moving forward. tractor has 430 hrs on it, and hydro filter and fluid changed at about 350 hours. I was grading the driveway and engaged in the ground pretty hard, and after that I noticed it hardly moves forward but moves backwards fine. Any ideas?
Disregard! Heres what happened after an hour of going over tractor. I had mud on my boots that picked up some rocks. the rock fell off the boot and prevented the forward pedal of depressing far enough to give it more power..my stupid mistake.
   / Losing Forward power on Hydrostatic #2
Most of us has had similar things happen. Glad you found the problem. Better you found it then some guy at $100 per hour.
2016 FORD F250 XL SUPER DUTY TRUCK (A51406)
2016 FORD F250 XL...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
