Snowblower Lorenz 734 and Kioti Dk4510HS
   / Lorenz 734 and Kioti Dk4510HS #1
ransonjd
Bronze Member
Rochester, NY
BCS 605
I'm looking at a used 7' Lorenz 734 as a possible snowblower to throw on my DK4510HS. The tractor is a 45HP shuttle shift with a Cat. 1 hitch rated for 2,716lbs 24" behind the hitch. The snowblower is made for a Cat. 2 hitch, 40-100HP and weighs 1150lbs.
Is this a good snowblower? Would this snowblower be too much for my tractor? And will I be able to fit the Cat. 2 blower to my tractor?
Location is Rochester, NY. I've got a 1000' gravel driveway.
--John
   / Lorenz 734 and Kioti Dk4510HS #2
Hello John,
The Lorenz snow blower line is of very high quality.
You need to see if you can purchase the conversion pins/bushings locally for the three point hitch
before you spend your money.
   / Lorenz 734 and Kioti Dk4510HS #3
If you can get the cat 1 pins on the blower, your tractor should handle the weight, IMHO
Bushings are available, but it looks like it sold yesterday. Shucks.
2000 PETERBILT 379 TANDEM AXLE SLEEPER (A52141)
2000 PETERBILT 379...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2012 Hino 262 Rollback Tow Truck (A50323)
2012 Hino 262...
2020 Exiss Escape 7306 LQ T/A Gooseneck Horse Trailer (A50323)
2020 Exiss Escape...
New 3pt Sod Cutter (A50774)
New 3pt Sod Cutter...
