Rims Loose lug nuts
   / Loose lug nuts #1
Bag Man
MF 4709
All four tires on my new tractor had loose lug nuts. By the time we caught it the holes were wallowed out on each rim. In all my years I have never experienced this. Have any of you ever had this problem on a new tractor?
   / Loose lug nuts #2
Never problem as such but I do check mine often.
   / Loose lug nuts #3
The dealer will either take care of you or blame you for not checking them. I suspect the manufacturer’s warranty will not cover replacement. Good luck.
   / Loose lug nuts #4
That happens quite often as others may attest. Happened to me but I caught it in time and only had to get new lugs on the rears and re-tap the holes.. The owners manual said to check nuts at 50 hours and to keep the correct torque on them. I only had 30 hours on when I caught mine. They were still usable after the correction and have been on for 9 years.
I hope the wheels aren't shot and are still workable. My suggestion if they are able to work would be to replace studs if necessary and put blue, #242, Locktite on lugs and torque to specs to keep them tight.
   / Loose lug nuts #5
Pre delivery must have been pretty thorough om my Massey. A little paint stripe on all the bolts, if one was a tad loose it would be quite obvious.
   / Loose lug nuts #6
Checked mine on delivery, all ok. After first 10 hours or so quite a few had loosened - not loose, but not at spec. Checked again around 25 and 40, all were tight. I have pretty rough land (gumbo mud in the summer turns into rutted concrete) and they take a beating so I will continue to check fairly often. Why not - it is easy, quick, and like checking oil it prevents a disaster
   / Loose lug nuts #7
I have one tire i have to tighten all the time.
   / Loose lug nuts #8
The lug nuts on my 4105 were marked like that when delivered (a texta/marker stripe)... however the stripe on the nuts didn't line up with the ones on the rim on most of them.
Well, I needed a torque wrench anyway, so after purchasing one I torqued them all. None of them budged = all in spec. So my JD Dealership must have 'verified' the factory marks during the wet-up/delivery inspection.
   / Loose lug nuts #9
Two tractors in 38+ years. Both were delivered with properly torqued lug nuts. Never had a lug nut loosen. However - on the Kubota - I put blue Lok Tite on each stud as I retorqued each one. I still check them all - every spring.
   / Loose lug nuts #10
Loosening lugs happens often on new wheels and sometimes on any wheel that has been recently installed.
My car trailer wheels had orange stickers reminding me to retorque after so many miles. I torqued those stupid wheels every 50 miles until they stopped taking torque. I had over 250 miles on it by that time. Steel trailer wheels are notorious for needing to be retorqued until they conform to the hubs.
I have a Mustang that requires that I drive it and retorque the wheels every time they are removed or they will loosen up. After it's been driven and retorqued they are fine until I remove them again but I still check before taking it to the track just in case.
This reminds me I need to check the torque on the new wheels I put on my JD.
Edit: I replaced all the tires and two new rear wheels on my John Deere about 70 hours back. I just checked and although none were loose they all turned a 1/4 to 3/4 turns to achieve proper torque.
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
Soosan 140 Hammer 30 ton Class (A52384)
Soosan 140 Hammer...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
ATTENTION PLEASE READ (A50123)
ATTENTION PLEASE...
