tonycampobasso
- Joined
- Jun 29, 2012
- Messages
- 8
- Location
- Medina, Ohio
- Tractor
- Ferguson TEA20-sold, but still in my heart. Ford 1710
I have a Ford 1710 2 wheel drive that had been running hot when brush hogging. It has fluid. Does not leak. I cleaned the radiator screen and air filter to no avail.
1st thought was to replace the thermostat, which I am in the midst of doing. I did notice the pulley that the fan blade is mounted on is a little loose. It does not wobble during operation, only if you manually try to move it.
As I removed the thermostat, I reached around to the front of the fan and noticed the at least one or two of the bolts/screws that holds the fan blade to the pulley are loose.
Any reason to believe that they are not just loose and need to be tightened?
While I am in the middle of this project, does it just make sense to swap out the water pump and call it a day? That was my original intention. But the bolts that hold the thermostat in place snapped and I have spent a lot of time removing them. I am now a little ‘gun shy’ of digging too much further.
Thoughts?
Thoughts?
