loose bolts
   / loose bolts #1
daedong
Veteran Member
South Australia
On my DK50 the bolts have come loose where the frame is bolted to the engine block, one bolt has even srtipped the thread from the block. Has anyone else had this problem
   / loose bolts #2
I was surprised at how loose the frame to engine block bolts were on my new CK30HST. I tightened them up with an air wrench when I first got the tractor last month.
Mike
   / loose bolts #3
This is a common thing with tractors.
You should check bolts on a regular bases.
If you find a loose bolt use blue loctite on it.
I don't think I would get the air gun out to tighten them, unless you know what you are doing.
   / loose bolts #4
<font color="blue"> If you find a loose bolt use blue loctite on it. </font>
On frame bolts as well as loader mount bolts. That can't be stressed enough.
   / loose bolts #5
I found a few when I first recieved my CK30hst. At 54 hours, I did my first service and gave the bolts another check. Nothing was lose.
   / loose bolts #6
My 1/2 air gun is in power, between a 12" rachet and an 18" bar!! It is no big deal hooked to a 4 hp compressor! But handy.
Mike
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
Case 721B (A47384)
Case 721B (A47384)
New Kivel 4200 lb. Skidloader Forks (A50774)
New Kivel 4200 lb...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
SET OF 48" QUICK ATTACH MAST PALLET FORKS (A51242)
SET OF 48" QUICK...
Unused 2025 CFG Industrial MX50R Mini Excavator (A50322)
Unused 2025 CFG...
