Backhoe Loose B21 FEL & Backhoe Control Arms
   / Loose B21 FEL & Backhoe Control Arms #1
Leozepolusa
Austin, TX
Kubota B21 & L47 TLB
Has anyone reduced the amount of free play in their control arms? I am trying to detrmine if replacing the sleeves (part no. 75595-72150) for a B21 is typically the way this is done. I have inspected the FEL control assembly, and it appears the issue is either the sleeves or the control rod pin holes wearing down (part no. 75540-62160). I compared the free play on a new B21 sitting on my dealer's lot with mine and there is a significant difference. I'm just trying to tighten things up on my unit comparable to new.
Thanks for the help.
   / Loose B21 FEL & Backhoe Control Arms #2
Reduced? My BX24 FEL joystick developed a significant amount of slop in about a year and a half. I found several loose nuts and actually a broken control block. The block ($122 for the part) was replaced under manufacturer warranty (2 years on the tractor, 3 years power train). I guess I just got used to the slop over that time since everything was still in working order. It was the additional lock whenever I curled the loader that got me to looking at the cause and that's when I saw the broken control block. When I got it back after the repair...WOW, dramatic difference.
2020 Kubota SVL 75-2 Skid Steer (A51573)
2020 Kubota SVL...
2011 INTERNATIONAL MA025 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2011 INTERNATIONAL...
1264 (A50490)
1264 (A50490)
New Wolverine Skid Steer Forks Attachment (A53002)
New Wolverine Skid...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
