Looking to replace Daewha NTE 111A3 12v Fuel Pump on Century 2535 (Kukje) tractor
   / Looking to replace Daewha NTE 111A3 12v Fuel Pump on Century 2535 (Kukje) tractor #1
DonWannaBother
South Carolina
Century (Kukje) 2535
How do I find a compatible pump? What is the desired fuel pressure? What other specifications do I need to know? Is there an engine make or model number that would tell me the fuel pump specs? TractorData dot com tells me that the engine is:
Kukje
diesel
3-cylinder
liquid-cooled
110 ci
Power (gross): 37 hp [27.6 kW]
Fuel system: indirect injection
Pre-heating: glow plugs
Rated RPM: 2600
Starter: electric
Starter volts: 12
   / Looking to replace Daewha NTE 111A3 12v Fuel Pump on Century 2535 (Kukje) tractor #2
I’d pull it off and take it to Oreilly, Autozone or NAPA. They should be able to provide one that will work for you.
   / Looking to replace Daewha NTE 111A3 12v Fuel Pump on Century 2535 (Kukje) tractor #3
My dealer told me what a replacement sold for and suggested that I install an aftermarket electric one instead. I bought a Mr Gasket electric fuel pump that worked great for several years, then died on me. I replaced it with this one from Amazon 2 years ago and it's been working good since then. I chose it because it was recommended by Amazon and really don't know if there are better ones for the money or not.
https://www.amazon.com/gp/product/B072M7P34C/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
   / Looking to replace Daewha NTE 111A3 12v Fuel Pump on Century 2535 (Kukje) tractor #4
I have a napa electric fuel pump on my Century 2535. It has been on there about 6-7 years. Works fine. Follow Granthol's suggestion and take the old one to a store. W. Jones
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2003 GMC C7500 16ft Cab and Chassis Truck (A51692)
2003 GMC C7500...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
377789 (A51573)
377789 (A51573)
