Looking to purchase a small control valve Eaton-Cessna
   / Looking to purchase a small control valve Eaton-Cessna #1
cschulz
Ortonville,MI
Kubota BX2660
EATON-CESSNA. Directional control valve for operating hydraulic cylinders. Compact design makes it ideal for small tractor and other low flow applications. Open center. Spring centering spool. Single spool to use on my Kubota BX
Not sure of the part number? If somone has info as to were a bouts and numbers I would much appreciate the help.
Thanks Chris
   / Looking to purchase a small control valve Eaton-Cessna #2
Unless you just want some specific valve, you can use most any hyd valve to operate a hyd cyl, like this one.
1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE
If your tractor pumps more GPM, then get a larger valve in terms of GPM.
Thanks JJ. I had thought the same thing but I have a tight area that I want to place it and the Eaton Cessna looks to be just right. Ill take a second look to see if the valve you showed will work though.
Chris
UNUSED FUTURE FT13CJ EXCAVATOR (A54756)
UNUSED FUTURE...
UNUSED 78" HYD ROCK GRAPPLE (A54757)
UNUSED 78" HYD...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2022 CATERPILLAR 980 WHEEL LOADER (A52705)
2022 CATERPILLAR...
