Buying Advice Looking to buy a B5200 DT
   / Looking to buy a B5200 DT #1
RetiredGuy
Oologah, Okie land
B5200 looking at
Hello all, just retired and moved back home to Oologah, OK from Phoenix, AridZona. Put in my 20 with the fire department there and found 6 acres with trees and grass. Love it!
Been looking at everything around for something reliable to mow mostly level terrain except for the bar ditch.
Just tonight a 4x4 Kubota B5200 DT with mower, drag box grader, and a landscape trailer showed up. I'm thinking from the 3 reviews I found, it might be a decent buy??
The tractor description is as follows:
Kobota B5200 4X4 tractor, 900 hrs. Befco 4ft pull type finish mower. 4 ft box blade with scafire teeth. 6'X15' landscape type double axle trailer with fold down ramp. Box blade and mower are good. Tractor has some very minor body damage, and the lights do not work. The tractor starts and runs like it should and everything else works. All one price. $4000, make offer. Serious only, face to face deal only.
So far, my education on this model tells me to look out for the steering linkage issue, possible hydraulic seals or o-rings leaking. One reviewer commented his had 1,400 hours on it with no problems at all except for a hydraulic pump he had rebuilt.
I'm brand new here, my first post. I'm looking for knowledge as to what is a fair price. This tractor retailed at $8,300 or so when new back in 1983.
Are small yard tractors still holding their value at 50% of new?
Hope all had a good Christmas, and wish all a great New Year.
John
   / Looking to buy a B5200 DT #2
That model has Engine-13HP PTO-11.5HP TractorData.com - information on all makes and models of tractors If the specs for the tractor meet the criteria in regards to your needs and what you plan to use it for, then why not make a bid. It surely sounds as if the seller would take less than the asking price. Along with the 2 pieces of equipment and the trailer, it sounds like a decent deal if everything is in working order. I don't know anything in relation to parts availability on that model though. Good Luck if you decide to make an offer.:tractor:
PT 500 Gal Water Tank (A50121)
PT 500 Gal Water...
JCB 409 AGT4 WHEEL LOADER (A51246)
JCB 409 AGT4 WHEEL...
Allis Chalmers 5020 (A50120)
Allis Chalmers...
2018 Kubota R530 (A50120)
2018 Kubota R530...
2013 Mercedes-Benz C-Class C250 Sedan (A50324)
2013 Mercedes-Benz...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
