Looking Help - Sub Compact field narrowed to 4
   / Looking Help - Sub Compact field narrowed to 4 #1
briwalkr01
Bumpass, VA
Hello all - I am looking for some help. I have been reading all of the postings attempting to learn from everyone's experiences, they have helped thus far. I have narrowed my final decision to the final three (mainly based on dealer availability and comparing the specs) -
John Deere 2305
Kubota BX2350
New Holland TZ26DA
or I am open to any suggestions that you may think is worthy hunting down a dealer. I seem to have plenty to choose from in my area (central Va).
I am going to talk to the third NH dealer this weekend (closer than the frist two), and just down the street from the Kubota dealer that services all of my Husqvarna equipment.
I am happy with the Kubota dealer based on their quailty of service and quantity of parts "on hand" etc. Helpful for those of us who like to fix it ourselves when we can.
Any comments would be helpful. I am pretty deadlocked between these three and am looking something to help on bubble to the top of the pile.
Thanks,
Brian
   / Looking Help - Sub Compact field narrowed to 4 #2
It would be helpful for you to describe _your_ use of the tractor ...
All those are nice tractors, but some subtle differences may make one shine for _your_ primary uses ...
   / Looking Help - Sub Compact field narrowed to 4 #3
Your not describing what you will be using the tractor for but it does look like your comparisons are apples to apples. So with that any of the 3 will be good. I think the New Holland may have a tad bit more HP which really doesn't mean much, but you may need it also.
Providing pricing is fairly close I would go with the dealer that you think is going to give you the best service after the sale and which one fits your butt the best. Just about what it narrows down to.
murph
   / Looking Help - Sub Compact field narrowed to 4 #4
Those tractors were on my final list as well when I bought mine a few weeks ago. As previously mentioned, Go to the dealers and at least sit on all of them, Drive them around or see if they will drop one off for a tour around your property. after driving all three, I was then down to two. Both dealers were great, Prices were fairly close for all 3 tractors (especially over the hopefully long lifetime of the tractor). I am no expert, but if you post more details about intended use (how many acres you will mow, FEL needed or not? doing any landscaping?, etc) I am sure you will get some good feedback. All three seemed to be great tractors and I am sure you will be happy with any of the, but drive them first and see which one fits you better ( I liked the joystick on the JD near your hip more than by the steering wheel on the Kubota, personal preference but neither is right or wrong). Enjoy the process /forums/images/graemlins/grin.gif
Oops - sorry about that - just my newbieness showing.
I have 6 acres on which I just finished building a house.
There are aprox 2 acres that I will finish mow, lanscape, and continue to expand the small vegatable garden started during construction.
The next 2 acres are wooded and were not well maintained. They need thinning - a lot of 15' - 20' tree too close together.
The final 2 acres are river front, wooded, and heavily overgrown with vines, briar patches, poison ivy, etc.
I have been working the area around the house with an ATV with an attached a Swisher dump bucket. It has worked pretty well for spreading the mulch & some top soil, but I have had to return the winch that drives the system twice in the first 9 months with electrical & gear issues. I will keep it around for the light jobs, but I am getting into the heavy landscaping, top soil over the drain field, leveling the old field (first 2 acres), building plant beds, building a fence around the first 2 acres, planting some trees and bushes, etc.
I am going this weekend to test drive and talk to the dealers. The pricing on these tractors in my area are less than $1,000 difference and not enough to sway my decision away from the right unit.
I am looking for one of the tractors above, and the following attachments
60" Belly Mower,
Front End Loader,
Arger (for fence posts and digging holes for trees, etc),
and possibly a grader box
Thanks for the help.
Brian
   / Looking Help - Sub Compact field narrowed to 4 #6
When you look them over, also look them under. I live in the woods and that's where my tractor does a good part of it's work. The smaller Deere's that I've looked at all seem to have a lot of stuff hanging down below that could get snagged on a rock, branch, log, etc. The Kubota you mentioned is pretty low to the ground, too. I'm looking in about the same size/price range in my shopping, but taller. The three you listed fall into the subcompact class by most standards.
You might want to look at the small compacts instead of a large sub. You'll get a little more ground clearance. I guess the best way to describe the difference is that a small compact looks like a farm tractor that has been shrunk while a subcompact looks more like a lawn machine on steroids. It sounds to me like the area down by the river will always be pretty rough terrain, possibly subject to periodic flooding and such. I think the ground clearance offered by a slightly bigger tractor will come in handy.
For Deere, check out the 2520 (?), the Kubota B7610, and the NH TC26. Have fun!
   / Looking Help - Sub Compact field narrowed to 4 #7
Brian,
All the tractors you are looking at are quality units but the amount of work you are proposing, especially considering the two acres of poorly maintained wooded area, is at about the limit of what you can expect a SubCUT to do in reasonable time. DaTeacha also points out the issue of ground clearance which would be important again for the wooded area work. Unless you are happy to make slow progress, you might want to move up a step to a CUT size. You don't need more horsepower than you are currently looking at so something like a Kubota B7510 and it's competitors would be the sort of size I am talking about. The same engine size CUTs are only a little more money than what you are looking at.
   / Looking Help - Sub Compact field narrowed to 4 #8
Find a well reputated brand you like, more important, find a dealer close to you, that makes you feel comfortable. Ask other costumers of their experienses with that dealer. Ask your wife if the color of the tractor is OK. Buy a model a little bigger than you thought of first. Read TBN and look for owners that bought too big tractors! A few dollars more on size and quality now, divided over the years you will own it, is well spent. And finally, NEVER buy anything smaller than your neighbor!!!!
   / Looking Help - Sub Compact field narrowed to 4 #9
Check them out on uneven terrain, if you have any of it where you live. If you have uneven terrain, the front wheels will need some flex, and you'll need a locking differential in addition to 4wd. Make sure you get them in 4wd when testing them out, too. Sometimes, you have to wiggle the forward/reverse pedals to get the lever in and out. When I tested out a BX about a year and a half ago, it didn't have much flexibility and could easily get high center or a wheel in the air, driving air. The newer BX could be better.
I went through this choice and ended up with a 4010 after testing the BX, B Kubota and 2210/401 JDs and looking NH. The 4010 isn't made any more but was the only one with a bit more ground clearance (that I need for uneven terrain and straddling my raised garden rows), yet was still short enough to fit underneath my garage doors without having to raise/lower the ROPS. (This might be another consid, if you haven't thought of it; my BIL recently bought a new truck that he discovered wouldn't fit in his garage.)
If you have any heavy lifting chores requiring fairly heavy 3 ph equipment, consider getting a tractor with a full Cat 1 3 ph. At the time that I bought, I think the 4010 was the smallest that met this requirment. The BXs at the time (could be different now) only had Cat 0 lift arms. You can buy bushings to allow use of the Cat 1 stuff, but the spread width could limit you on some equipment. Think the JD 2305 may be the only one with Cat 1 capability among the 3 you've mentioned. Next step up now in JD is the 2520.
Ralph
   / Looking Help - Sub Compact field narrowed to 4 #10
All Kubota BX tractors are full cat 1 and will fit any cat 1 implement. The problems arise due to the short stature of the tractor that limits lift height.
The 2006 BX's are better, but the use of Sub-Cut implements by manufactures such as the Woods Estate series and King Kutter BX series is a good idea.
2018 Rock Solid 8x28 Cargo Trailer - Generator & A/C, Work-Ready (A52748)
2018 Rock Solid...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
2014 MACK CHU DAY CAB (A52472)
2014 MACK CHU DAY...
2002 INTERNATIONAL 4400 BEVERAGE TRUCK (A52576)
2002 INTERNATIONAL...
378786 (A51573)
378786 (A51573)
Deere 9965 Cotton Picker (A52748)
Deere 9965 Cotton...
