Looking for suggestion for Hydraulic Fluid for Mahinda 3525
   / Looking for suggestion for Hydraulic Fluid for Mahinda 3525 #1
Bob3525
Only see 2 listed in Manual Chevron 1000 THF Texaco - TDH Oil Special
Does anyone know the specs. I need to look for from fluid from Walmart or Tractor Supply or a suggested brand of fluid to use.
Walmart has a brand Warren 303 or Warren Oil WARTTHF6 1 gal Tractor Hydraulic Fluid, would this be good ?
   / Looking for suggestion for Hydraulic Fluid for Mahinda 3525 #2
Most mahindra call for universal tractor hydraulic fluid GL4 , don't use Warren if it don't state GL4 , the least costly I've found is Sinopec universal tractor brake fluid it's gl4 rated 10w30 it held up great but I used in my emax25 with hst , ordered through walmart.com. Other than that the mahindra universal tractor hydraulic is good as any, chevron 1000 I hear is also good stuff but make sure you getting a api GL4. I've tried several different products tractor supply fluids if I recall don't state gl4 while she'll rotella did have the specs but broke down quickly so I don't use any she'll product in my tractor. Problem with gl5 fluids / oils is its harsh on yellow metals like copper , brass, that's why GL4 is used in machines apparently copper or brass is used in the transmissions plus gl5 could harm seals causing leaks. Personally I keep away from Warren in newer tractors and equipment. If a good fluid at a price that's reasonable go with Sinopec around $45 for five gallons and free shipping, when I purchased it was around $38.
2014 PETERBILT 367 (A52472)
2014 PETERBILT 367...
2022 Club Car Tempo Golf Cart (A51694)
2022 Club Car...
MILLER SYNCROWAVE 351 TIG WELDER (A52472)
MILLER SYNCROWAVE...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2011 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER TRUCK (A52577)
2011 INTERNATIONAL...
